Second question please
grumpy2
#1 Post by grumpy2 »
Trying to track down some clutch judder and changing the UJs on the prop shaft.
Appreciate an opinion on the centre bearing (photos) and the gearbox centre mount.
I thin the box mount looks ok but uncertain about the centre bearing
Re: Second question please
#2 Post by Jon Tilson »
As I think I said the box mount doesnt look tight enough.....
grumpy2
#3 Post by grumpy2 »
Thanks for the reply. Things moved on a little from here
Decided to change it anyway, bugger to get off working on axle stand with a dodgy old body (mine not th ears)
When off the car it was soft and had gaps at the sides, replaced with a new one and happy to report everything is fine and dandy.
Judder gone
New one was even harder to get back in place, total work time around 3 hours.
