Page 1 of 2
Laptop charger (Dell)
Posted: Wed Dec 20, 2017 7:24 pm
by tony g
I have about 4 laptop chargers for Dell. As it converts AC to DC (19v), can I chop off the mains part and put a 12v plug for the ciggy lighter to charge it?
Re: Laptop charger (Dell)
Posted: Wed Dec 20, 2017 7:46 pm
by Mahesh
No, it's a/c to dc.
What you need is a 12v to 19v dc to dc adaptor/converter at the minimum amperage rating as the mains unit.
Posted: Wed Dec 20, 2017 7:48 pm
by Mahesh
Forgot to add,
I did have some at work, just a question of finding, will have a look
tomorrow.
Posted: Wed Dec 20, 2017 8:46 pm
by tony g
Mahesh the car is DC so if the AC part isnt here its just DC in and out isnt it?.
Posted: Wed Dec 20, 2017 9:17 pm
by Mahesh
At 12v it would be a very slow charge for the laptop, and no chance of charge and use at the same time.
I'll check at work if I can find the universal ciggy socket to laptop power supply, they are voltage adjustable and voltage regulated on the output, it's a question of where I put them.
Posted: Wed Dec 20, 2017 9:21 pm
by tony g
Ive just go the gist of it now lol. 19v and 4.62a needed :)
Posted: Thu Dec 21, 2017 5:23 pm
by MIG Wielder
Hi Tony, One way of doing this is to use a 12V to 230Va.c. power inverter. Like one of these.
https://www.maplin.co.uk/search/?text=1 ... +converter
From experience they are not good at powering lighting loads as the cold input current is much higher.
Also some have pseudo sine wave outputs which some pieces of electronic equipment doesn't like as they electronically chop the voltage up and give high peak input currents. Maybe take the charger in and tell them what you need.
HTH,
Posted: Thu Dec 21, 2017 5:42 pm
by Galileo
You need a 12v to 19v DC-DC Buck, eg. https://www.amazon.co.uk/Supply-Convert ... B01EV59JZG
Posted: Thu Dec 21, 2017 7:00 pm
by oily66
When I used to be on sales I had to d quotes on the road, i bought a 150w inverter and it did the job admirably.
I also used it when camping for the 230v Air pump although rated at 200w the inverter coped for the very short time needed, as it spun like the clappers.
Posted: Thu Dec 21, 2017 8:08 pm
by Galileo
You don't get something for nothing in physics, so 12v to 230v to 19v is massively inefficient!
Posted: Thu Dec 21, 2017 10:16 pm
by tony g
Posted: Thu Dec 21, 2017 10:36 pm
by Galileo
Older Dell Lattitude's have a 7.4mm x 5.0mm barrel, so as long as the listing is correct, so yes in theory but they do not list the wattage in the listing. For example this model Lavolta charger http://amzn.eu/gHxAPj4 (sorry for all the Amazon links, they just handily have everything with specs) will work with a Dell Lattitude D610/D820 because it's 19v/90watt with a 7.4x5mm barrel even though the listing doesn't mention a Dell, it's £13.49 if you have an Amazon Prime account.
Posted: Thu Dec 21, 2017 11:01 pm
by Mahesh
No joy at finding one at work today, will have a good look over this weekend for you.
I had the uniross universal type, which is a lot better made than the ones on Ebay at the moment.
If you could post your laptop model number, the correct dc plug size can be ascertained.
Posted: Thu Dec 21, 2017 11:17 pm
by tony g
ok thanks Mahesh, mine is Dell latitude d630 with a fat round pin :)
Posted: Sat Dec 23, 2017 11:15 am
by tinweevil
You could get one of these::
https://www.ebay.co.uk/itm/New-Genuine- ... 3260981817
The only down side is at 65W it will not run a beast of a laptop while you play Crysis but on the up side nor will it melt your car wiring. It will run a laptop hard enough to watch a film, do general stuff or recharge it when off.
