Anybody know what options there are for the speedo for a 73 Spirint? Like the 1850, etc. And would anybody have one they'ed part with for a reasonable sum?
My cable's gone and left part of itself in the back of the head.
I'm gonna try and take it appart to push/pull through from the front - too hard to drill -, but I'm not hopeful of getting it back together and it working properly after.
Sprint Speedo
- GrahamFountain
Sprint Speedo
Re: Sprint Speedo
There’s one ending soon on eBay for £20
Think I’ve got one in the loft somewhere too
- GrahamFountain
Re: Sprint Speedo
Seen that and messaged about P&P. There's also a couple of 120 mph 1000 turn ones for £30. Will the front of mine fit that and read right, presupposing I can get the pointer on right?
- GrahamFountain
Re: Sprint Speedo
Seller added P&P while I was wondering, so Ive bought it. It's not a match, looks like a pushbutton trip reset, but that's not a big issue.
Re: Sprint Speedo
not sure what type mine is but my car is a late sprint. Came with a load of bits and bobs though.
good luck tinkering
good luck tinkering
Re: Sprint Speedo
All Triumph speedos are 1000TPM so the gearing will be OK. The correct instrument for an early Sprint will have the "easyread" font, marked in 10mph increments to 140mph, a remote trip zero cable fitting on the rear and probably clear, rather than green, illumination. Not sure I have one that early, but i'll have a look over the weekend.
- GrahamFountain
Re: Sprint Speedo
That would be great, as the one I've bought is a later one with a push reset and scale to 130. But I would prefer the right one if possible.Carledo wrote: ↑Tue Jan 02, 2018 9:52 pm All Triumph speedos are 1000TPM so the gearing will be OK. The correct instrument for an early Sprint will have the "easyread" font, marked in 10mph increments to 140mph, a remote trip zero cable fitting on the rear and probably clear, rather than green, illumination. Not sure I have one that early, but i'll have a look over the weekend.
It was my own damned fault - fitted a lights left on alarm (buzzer and two scotch-locks) behind the dash, and must have put the spedo cable back in wrong. It worked oddly for 200 yrds then stopped.
