Helicoil error, no compression
cleverusername
#1 Post by cleverusername »
I had to helicoil number one spark plug and I did it slightly off square. This means no compression cylinder one, because I can't torque the plug down. Too many turns and the socket gets stuck.
I am hoping that an extra long socket will let me torque it enough. Otherwise one dumb mistake may have trashed the head.
Happy days.
Mark....
#2 Post by sprint95m »
If you were to remove the rocker cover and the No. 1 cylinder spark plug tube
would that give sufficient space for the socket?
Re: Helicoil error, no compression
#3 Post by soe8m »
Conical seat. Off square and it will never seat and seal. Maybe you can try another type plug what seals with a ring. Not ideal but a bit more forgiven.
cleverusername
#4 Post by cleverusername »
soe8m wrote: Sun Feb 04, 2018 4:37 pm Conical seat. Off square and it will never seat and seal. Maybe you can try another type plug what seals with a ring. Not ideal but a bit more forgiven.
Yep, I guessed that. Of course when I did it I thought the thread were the gas seal.
Magenta Auto Sprint
#5 Post by Magenta Auto Sprint »
There are two types of heli-coil kit, one is a proper circular plug with a flared top and the other cheaper one looks like a coil of wire; which one did you use?
The first one uses a tap that picks up on the old thread and guides it till the larger new thread starts to cut and then leaves a small counter sink for the heli-coil to seat in, so it should all be reasonably square.
I would think that the head could still be saved.
Malcolm
