My SPRINTS HS-6's have recently been rebuilt.
Just the other day, before the thing developed a water leak, I managed to get it running beautifully.
The mixture settings are just right, but, I've run out of idle/airflow adjustment with the screws loose-ish in the threads.
Like I said, its running nice with good, crisp throttle response but its idling at 1,000-1,100 RPM (should be 750?) and although I think I can get it marginally lower I'm concerned I'll lose the idle adjustment screws altogether.
Any advice?
Thanks & Cheers,
Rob
Fast idle problem
Re: Fast idle problem
sounds like an air leak somewhere.
Malcolm
Malcolm
Throttle cable have enough slack~? Choke linkage touching the "cams"? Best to make sure its all slack then see what happens.
If your SUs have been rebuilt, pound to a penny the throttle discs aren't quite lined up. I have just had the same issue on my 1850. The smallest amount of gap around the discs when the throttle is closed will cause a rise in revs. I took my carbs off again, removed the chamber and piston and then looked through the carb with a bright light behind. The gaps around the disc were obvious. I slackened the butterfly disc screws and wobbled the disc this way and that until the gaps were at their absolute minimum. Put everything back and, presto, it works properly.
What he said^^^^^
And just check the choke fast idle screws are not too far in and stopping you from dropping it properly!
What they said.
Nothing to add.
