poly bush Kit
poly bush Kit
Just wondering what kit people use and why such a difference in price, flo flex seems to be half the price of other brands at £98 for front and rear.
Thanks Pete
Thanks Pete
- yorkshire_spam
Re: poly bush Kit
I tried flo flex on a land rover, they were utter rubbish. I only use super pro, super flex or original polybush.
Re: poly bush Kit
Is rob sport the best supplier or do the club do poly bushes, i was told the front of my car is already poly bushed so need a rear kit.
i will steer clear of flo flex then
Pete
Pete
Re: poly bush Kit
you said you didn't like flo flex,why whats wrong with them ? Ive bought the front and back kit for the dolly not fitted yetyorkshire_spam wrote: ↑Sat Mar 03, 2018 9:10 pm I tried flo flex on a land rover, they were utter rubbish. I only use super pro, super flex or original polybush.
Re: poly bush Kit
Chris Witor does Super Flex, These are top quality and though they are not cheap, they are the best and Chris gives club members a 10% discount.
You may want to cherry pick the rear bushes, the wisdom on here is to only polybush the rearmost trailing arm bushes and the rear (axle end) upper link bushes and stick to rubber for the rest. Full poly seems to destroy trailing arms due to it's inability to absorb twist loads.
Re: poly bush Kit
Chris Witor Superflex, accept no other.
Re: poly bush Kit
They don't fit well - or last long!new to this wrote: ↑Sat Mar 03, 2018 10:06 pmHi whats wrong with flo flex ? Do they not fit properly ?
Re: poly bush Kit
Thanks,looks like ive bought the wrong poly bushes
- yorkshire_spam
Re: poly bush Kit
The flo flex I tried on my Landy just fell apart in about 12 months. Maybe they've improved since then?
Re: poly bush Kit
I wouldn't fit anything other than Superflex bushes, unless I'm being a cheapskate and using original rubber ones, as you know you are getting quality that will last from a well known respected supplier with an excellent track record.
Some of the cheaper ones, especially those cheap found on Ebay may not be the same compound, afterall they are usually cheap for a reason.
- going_downhill
Re: poly bush Kit
I went with SuperPro from Rob sport. 10% discount to TDC members if I remember correctly. The reviews of Flo flex online is enough to say domt bother, everyone mentions poor fitting and poor longevity. But I've no first hand experience with them, it's just the time and effort it takes o fit a bush kit, do you want to be doing it again in a year..
1980 Russet 1850hl
- SprintMWU773V
- TDC Staffs Area Organiser
Re: poly bush Kit
I've gone for Superflex in most places with the exception of the rear trailing arms where I used the comfort grade Polybush branded ones. They have the advantage of being in 2 halves so much easier to fit and are as flexible as the original rubber ones which is probably better for the mounting points on the body.
- going_downhill
Re: poly bush Kit
Also, just so you know. If you buy a SuperPor kit from Robsport, the bushes are not all the same poly. Some are softer than others. I think some were even black, rather than the go too purple.
Your floflex stuff will all be exactly the same.
1980 Russet 1850hl
