1850 Chain tensioners
dollyman
TDC Cheshire Area Organiser
#1 Post by dollyman »
Hi All,
There was not long ago a post on dodgy chain tensioners and slipper pads......
I cant seem to find it :( :(
Can anyone tell me how to identify them and which one's to avoid :wink:
Cheers,
Re: 1850 Chain tensioners
#2 Post by Carledo »
Avoid anything with "Rolon" written on it!
Seeeeemples!
#3 Post by xvivalve »
To be fair, the only reported failures thus far have been with the Sprint duplex style tensioner.
The simplex style, 1850, TR7 et al, have far greater application, and may have safety in numbers. I think it will be far harder to avoid Rolon with the simplex variety, but yes indeed, they are the culprit with the duplex failures.
It may be that current stock just means production hasn’t switched to the defective factory...
Bumpa
#4 Post by Bumpa »
I had my 1850 engine in bits recently and had bought a new tensioner from one of the usual Triumph suppliers. Yes, it was a Rolon and it differed from the original in several ways, not least in the tiny, tiny hole for the oil passage. Since the original tensioner had only done about 60,000 miles and had minimal grooves from the chain, I put it back rather than risk the Rolon. I think you will be hard put to find a new tensioner that isn't a Rolon, and who knows they might be fine on the single row chain. I just didn't want to risk it.
#5 Post by Toledo Man »
I've moved the thread here because it is "Dolomite-related".
dollyman
#6 Post by dollyman »
Many thanks everyone thats a big help :D :D
Cheers,
Sundowner
#7 Post by Sundowner »
Tony,
There have been several threads on tensioners. This is one I started regarding my SPRINT. viewtopic.php?t=30444
The problem isn't about the size of the lubrication hole its more about the quality of the bonding between the slipper pad and its metal base. I now have a Jaguar item installed and due to these pics and this article, that's all Robsport will sell you now.
Yep, Rolon definitely is rubbish.
Rob
dollyman
#8 Post by dollyman »
Hi Rob,
Thanks for that, this is the one i had seen before.... Great to find it again :D
Cheers,
cleverusername
#9 Post by cleverusername »
So it is a Jag bit from Robsport? Didn't know that.
I am amazed that a car part supplier can't find an adhesive that can reliably stick rubber to metal. It seems pretty basic stuff.
#10 Post by xvivalve »
THE JAG ONE IS NOT COMPATIBLE WITH AN 1850. THERE HAS NOT BEEN A PUBLIC FAILURE OF AN 1850/TR7 ROLON ONE YET.
THE JAG ONE IS SLOWLY BEING SUPERSEDED BY SOME SUPPLIERS WITH THE ROLON BRAND TOO
SprintMWU773V
TDC Staffs Area Organiser
#11 Post by SprintMWU773V »
Has the Stag world had any failures? I think they are the same.
dollyman
#12 Post by dollyman »
SprintMWU773V wrote: Fri Mar 09, 2018 10:04 am Has the Stag world had any failures? I think they are the same.
I was thinking that as well :? Anyone heard of it?
Cheers,
