Quality 1850 head gasket set
- yorkshire_spam
Hi all, I suspect Binny (aka RUK) might be suffering head gasket failure (unexplained coolant loss, steam from the exhaust pipe in large amounts and even after a good long run out - I'll get it chemically tested though)
Anyway, can anyone recommend a source of quality head gasket sets for an 1850? For the Spitfire I'd use Payen, but I haven't found a Payen set for the 1850 yet (I thought I'd won one on eBay, but the seller cancelled the sale selling they were "out of stock" )
Cheers, Sam
Cheers, Sam
Re: Quality 1850 head gasket set
I have been tasked by the late Mr Tilson to assist Mrs Tilson in clearing his sheds, garage, loft and driveway (it’s ok, he asked me before he passed on, not after!)
I’ve only done a preliminary recce so far, but I did notice some 1850 Payen gasket kits on a shelf.
A sensible offer to widow Tilson will secure one for you, but it will be a couple of weeks before I’m down there again...
Do you know why it is failing? Is it down to a low quality gasket or is there a more fundamental problem? Changing the gasket without fixing the root cause will be a temporary solution.yorkshire_spam wrote: ↑Sat Mar 10, 2018 8:10 am Hi all, I suspect Binny (aka RUK) might be suffering head gasket failure (unexplained coolant loss, steam from the exhaust pipe in large amounts and even after a good long run out - I'll get it chemically tested though)
Cheers, Sam
- yorkshire_spam
No idea until I start investigating properly, first I have the Spitfire diff to rebuild, I'm not having both motors in bits at the same time.cleverusername wrote: ↑Sat Mar 10, 2018 10:47 am Do you know why it is failing? Is it down to a low quality gasket or is there a more fundamental problem? Changing the gasket without fixing the root cause will be a temporary solution.
I'll get the head tested and checked for flat though.
That's ruk it happened. But is it a stromberg one? Do these have an extra waterways under the inlet manifold? I would check first thoroughly before just taking the head of.
Oh no! Sam you should have messaged me! I think I have a payen one that you can have, let me check.
Thinking about it when it was at the NEC in November the chaps who used to service her came onto the stand and said that they fitted a new head in the early '90s.
Sam, try a leakdown test. If it's that bad there will be bubbles appearing in the header tank.
Shout if you need anything
I'm afraid the last one I have I need for DTR.
Did I give you a gasket set? That should be a payen one.
- yorkshire_spam
Thanks Guys, I'm going to do a chemical test on the coolant before I do anything else.
Now that you mention it James, there might have been a head gasket in the parts you gave me - I'll go and check!
With the amount of steam coming out of the exhaust pipe I'm fairly sure there's something other than just a water leak going on. But I'll keep an open mind.
- yorkshire_spam
Thanks Jeroen, I think given how much more there is involved removing the heads on these compared with things like the 1500 engine I'll try and rule everything out before I take the head off. But if I go to all that trouble I'll get the head tested.
It's ok as long as the studs come out.
All of the anclary components have been off before so they should be ok. I have had the inlet manifold off and refitted with new bolts, the exhaust is still relatively new with brass nuts so they should unbolt easy as pie.
- yorkshire_spam
Thanks James, I keep flipping mentally between "sure it's the HG, how else could it be steaming like that" and "stop being paranoid, it's cold weather of course it's steaming, it's just a leak somewhere"James467 wrote: ↑Sun Mar 11, 2018 12:45 pm It's ok as long as the studs come out.
I'll give it a chemical test, check for mayo and run it up to temp with it parked over a large sheet of clean cardboard and see where I'm at.
Petrol produces ten times its own weight in water when it burns; in this weather, that's a lot of steam!
When I did the head on SWK 4 years and 22,000 miles ago I just used one of Mr Rimmers off the shelf head gaskets and its been fine. No problems.
Tony, this Sam is who I was referring to to test the headmaster.
Sam, I'd just pull the head and replace the gasket, it's the only thing I didn't do on the car. At least you'll have peace of mind for the RBRR and you can have a quick look at the bores.
You can test Tony's new headmaster head removal tool!
