Odd front brake disc wear pattern.
#1 Post by MIG Wielder »
Hello All, What has gone wrong here do you think please ? This is on a daily driver 1850 Dolomite and the outer 1 inch radius of the disc is horribly pitted & rusty; worse than anything I have seen on anything that has been laid up for years. The pads are nearly new and are NOS Unipart and are fairly flat over most of the operating surface. And the calliper pistons are both moving freely in and out. The brakes just feel good and solid on the road. The offside disc is fine.
So what is causing the pads to run on the inner 2/3 of the disc and why aren't they cleaning the outer 1/3 of the disc ?
Thanks,
dolly disc290518.jpg (101.61 KiB) Viewed 1230 times
tamtrucks
Re: Odd front brake disc wear pattern.
#2 Post by tamtrucks »
has the disc got the same thickness throughout the braking surface? could your bearing need replacing or excessive play
#3 Post by Carledo »
I change out discs like this all the time Tony, mainly on MOT failures. Classics, modern, single, vents, front, rear, RWD, FWD, there doesn't seem to be any common cause for it, it just happens! And generally speaking, there is a confusing lack of imbalance when the car gets to the rollers too!
TrustNo1
#4 Post by TrustNo1 »
Piston not pushing out square with pad.
#5 Post by tony g »
TrustNo1 wrote: Tue May 29, 2018 12:21 am Piston not pushing out square with pad.
I thought that too. Also if the pad gets jammed in the caliper and tips slightly towards the end of travel it could cause this. I would expect the pad to be slightly tapered there too.
Tony is the inside face of the disc clean?
dollyman
TDC Cheshire Area Organiser
#6 Post by dollyman »
Like Steve say's, i have had the same thing on many cars, and like you only one side. More often than not it will be an advise on the mot as it does not cause a brake in balance.
Personally if its not causing a problem? I would leave it :D What would others do?
GTS290N
#7 Post by GTS290N »
Personally I think the braking surface is small enough without adding to the problem....
#8 Post by Carledo »
dollyman wrote: Tue May 29, 2018 11:31 am
More often than not it will be an advise on the mot as it does not cause a brake imbalance.
There seems to have been a change in DVSA's instructions to testers concerning just this fault in the last 18 months or so. Where it used to be acceptable or just an advise in the past, it is now a reason to refuse. As witnessed by the huge pile of brake discs in my scrap pile! They are actually beginning to outnumber broken coil springs!
dollyman
#9 Post by dollyman »
Carledo wrote: Tue May 29, 2018 10:39 pm
Probably my guy being helpfull, but i have to say if he comes up against any of the newer vented stuff with the same problem....... They do end up with the spring's.
#10 Post by MIG Wielder »
Hi All, Thanks very much for all your comments and hints as well. I was also thinking along the same lines as wheel bearings, ( they were a bit slack) and brake pistons skew but they seemed to be moving O.K. Anyway, seeing as its MOT time coming up I've just added the old disks to my own pile of scrap metal.
And yes, the inside surface was just as bad as the outer surface. I was wondering about Winter road salt, but we didn't get a lot of that spread round here last Winter.
TrustNo1
#11 Post by TrustNo1 »
can't be failed if it can't be seen ;)
(kinda written in jest)
