carburettor oil
Posted: Mon Jun 25, 2018 8:14 am
by wellskint
i have a vague note that oil needs topping up in the carb? if so, any info on what sort of oil, where to fill it etc. tahnks
Re: carburettor oil
Posted: Mon Jun 25, 2018 8:51 am
by cliftyhanger
Engine oil, 20/50 best.
Don't be tempted by thin oil, it doesn't give enough enrichment during acceleration.
Re: carburettor oil
Posted: Mon Jun 25, 2018 9:00 am
by Bumpa
The carbs shouldn't need constant topping up as there is nowhere for the oil to go. It is only there as a damping medium. Unscrew the plastic cap on the top and pull the plunger out, then push it back in. If there is resistance to pushing it in, you have enough oil.
Re: carburettor oil
Posted: Mon Jun 25, 2018 12:39 pm
by Toledo Man
ATF can be used and one of my CT friends (you'll probably know him Clive. he goes by the name of "Mik") uses a mixture of 20W50 and 3-in-1 in his 1500 racing Spitifre. I believe that SU can supply dashpot oil. None of these recommendations (including the engine oil) are wrong so use whichever works best for you.
Re: carburettor oil
Posted: Mon Jun 25, 2018 1:53 pm
by tangocharlie1
Just use the SU Dashpot oil, it is not very expensive and should last for ages. I think you can pick up a bottle for about £6.
Re: carburettor oil
Posted: Mon Jun 25, 2018 2:24 pm
by Galileo
Hang on a moment, they rarely need topping up? Every car with SU's I've ever had needed topping up regularly and forget using thin machine oil as that used to vanish in no time, what am I doing wrong?!
