carburettor oil
wellskint
carburettor oil
#1 Post by wellskint »
i have a vague note that oil needs topping up in the carb? if so, any info on what sort of oil, where to fill it etc. tahnks
cliftyhanger
Re: carburettor oil
#2 Post by cliftyhanger »
Engine oil, 20/50 best.
Don't be tempted by thin oil, it doesn't give enough enrichment during acceleration.
Bumpa
Re: carburettor oil
#3 Post by Bumpa »
The carbs shouldn't need constant topping up as there is nowhere for the oil to go. It is only there as a damping medium. Unscrew the plastic cap on the top and pull the plunger out, then push it back in. If there is resistance to pushing it in, you have enough oil.
Re: carburettor oil
#4 Post by Toledo Man »
ATF can be used and one of my CT friends (you'll probably know him Clive. he goes by the name of "Mik") uses a mixture of 20W50 and 3-in-1 in his 1500 racing Spitifre. I believe that SU can supply dashpot oil. None of these recommendations (including the engine oil) are wrong so use whichever works best for you.
tangocharlie1
Re: carburettor oil
#5 Post by tangocharlie1 »
Just use the SU Dashpot oil, it is not very expensive and should last for ages. I think you can pick up a bottle for about £6.
1973 Triumph Dolomite Sprint
1972 Triumph Stag
1973 Triumph TR6
Galileo
Re: carburettor oil
#6 Post by Galileo »
Hang on a moment, they rarely need topping up? Every car with SU's I've ever had needed topping up regularly and forget using thin machine oil as that used to vanish in no time, what am I doing wrong?!
