Indicator light sealing/backing gasket/sponge
Mahesh
#1 Post by Mahesh »
Does anybody sell these ?
The one that goes behind the lens is readily available.
But not this one, which is located betwwen the body and fitting.
Or should I just make my own ?
Re: Indicator light sealing/backing gasket/sponge
#2 Post by Mad Mart »
Go on, make them yourself Mahesh. You know you want to.
new to this
#3 Post by new to this »
Mahesh
Sorry to. Hijack but where do I get captive screw fixings for the sidelight /indicator
Thanks Dave
Mahesh
#4 Post by Mahesh »
new to this wrote: Mon Jun 25, 2018 6:46 pm Mahesh
Sorry to. Hijack but where did I get captive screw fixings for the sidelight /indicator
Thanks Dave
They are the originals, but I believe they are readily available, also swapped a 730d bootlid last year and found the same type in there.
#5 Post by Carledo »
Thanks Dave
Bresco, Fitchetts, Rimmers (roughly in that order) original Triumph part number is 90/79075.
new to this
#6 Post by new to this »
Carledo wrote: Mon Jun 25, 2018 9:46 pm
Thanks Dave
Looked on Bresco but couldn't find the clips
Thanks Dave
oily66
#7 Post by oily66 »
Try this
https://www.bresco.com/acatalog/Snap-In ... ubber.html
in the middle near the bottom.
Trevor
2017 Jaguar XE R-sport
Mahesh
#8 Post by Mahesh »
Not the best of jobs, but it will do for now,
new to this
#9 Post by new to this »
oily66 wrote: Wed Jun 27, 2018 1:41 pm Try this
thanks missed that
Thanks Dave
new to this
#10 Post by new to this »
Mahesh wrote: Wed Jun 27, 2018 2:56 pm Not the best of jobs, but it will do for now,
Mahesh
Just looked on Rimmers site they sell the gasket,
Mahesh
#11 Post by Mahesh »
new to this wrote: Wed Jun 27, 2018 9:12 pm
Mahesh
I've found the one between lens and fitting, but not the one that goes behind the light fitting to the body, can you post a link, I'm curious to see where on the site.
If it's a sponge one, my xps laminate flooring backing polystyrene gasket is probably superior, and watertight :)
new to this
#12 Post by new to this »
Mahesh wrote: Wed Jun 27, 2018 9:39 pm
Mahesh
Mahesh
I've got a spare light fitting with the rubber gasket,but the gasket has a split in it but apart from that will clean up to
Mahesh
#13 Post by Mahesh »
Mahesh
[/quote]
Many thanks Dave, but I have since found my earlier lights, i now need a rubber boot for the back.
I know they are wrong for a later car, but do prefer the look.
