Sprint servos back in stock
#1 Post by xvivalve »
Reconditioned Sprint servos are now back in stock in limited quantity. They are £145 exchange on the basis that the supplied unit is viable.
Research continues regarding remanufacture of the critical Bakelite diaphragm both as a machined and welded aluminium component but also as a 3D printed component
Meanwhile, avoid pressing your brake pedal if your master cylinder is either empty of fluid or not fitted to the car.
