Wiring diagram
new to this
Wiring diagram
#1 Post by new to this »
there's two fuses in a dolomite, is one permit 12volt and the other ignition supply , also for the heated rear window should there be a relay
Thanks Dave
Re: Wiring diagram
#2 Post by soe8m »
Dolomites don't do relay's. Pure good old amps through the switches.
Re: Wiring diagram
#3 Post by Mad Mart »
Yes, one is permanent the other is through the ignition switch. There should be relays on a lot or circuits...but there wasn't from the factory.
new to this
Re: Wiring diagram
#4 Post by new to this »
Thanks Mart and Jeroen
Mahesh
Re: Wiring diagram
#5 Post by Mahesh »
Relays need more cabling and cause connecting confusion on the assembly line, thus a reason to strike, easier to buy high amperage expensive dc switches.
GTS290N
Re: Wiring diagram
#6 Post by GTS290N »
Mahesh wrote: Mon Jul 09, 2018 8:49 pm Relays need more cabling and cause connecting confusion on the assembly line, thus a reason to strike, easier to buy high amperage expensive dc switches.
And when things go wrong a fire means a new car. Good marketing strategy. :lol:
Galileo
Re: Wiring diagram
#7 Post by Galileo »
I still think of relays as a novelty, and I'm not that old, as all the cars I had growing up never had relays or if they did it was just the one like for the horn.
Mr Lucas has been a tad unjustly maligned, just as with any other, at the time ubiquitous, mass producer of product they build and deliver to a cost. Could be worse, like the Magneti Marelli stuff I've encountered in years gone past!
Re: Wiring diagram
#8 Post by soe8m »
Galileo wrote: Mon Jul 09, 2018 11:31 pm Could be worse, like the Magneti Marelli stuff I've encountered in years gone past!
It's very hard to make exact reproductions of Italian harnesses. It's almost unnatural to fabricate because I'm always tempted to improve because that's so easy to do.
