Hi All
Got a few questions about the brake disks dimensions and caliper mounting dimensions.
I know this isn't really information I'm expecting to be common knowledge, but I've decided to make a brake kit for my (soon to be) modified dolomite out of Jaguar S Type calipers and 304mm mg tf disks but need some dimensions of the existing dolomite disk and caliper mounting arrangement.
mainly, I need disk offset, which i think is around 22mm, and caliper mounting surface to disk face, which might be about 40mm but I'm unsure.
thank you very much
Max
Brake query
Brake query
Re: Brake query
I'm not sure but when you start such a modification you made some measurements yourself and have a vertical link laying on the workbench with the rim what's going to be used next to it.
Jeroen.
Jeroen.
