Heater box
Posted: Sun Aug 05, 2018 10:40 am
by sprintchris
Hi,
Taking the heater box out of the Sprint as I want to take it apart and clean it out, it’s pretty much caked in years of dust and grime.
Would anyone know of any links showing a unit dismantled, I see it’s all riveted together so I’m assuming not intended to be taken apart.
Many thanks in advance.
Chris.
Re: Heater box
Posted: Sun Aug 05, 2018 1:23 pm
by Richard the old one
I have just had to replace the heater water control valve as it had started to leak. I did it while it was in the car but it was not an easy job due to its location. I suggest if you have the heater out I would consider replacing the valve. The complete valve cost about £45.
Re: Heater box
Posted: Sun Aug 05, 2018 8:44 pm
by Flyfisherman
sprintchris wrote: Sun Aug 05, 2018 10:40 am Hi,
Chris.
Chris
you can take this item to peices - everything comes out at one end, dismantle the linkages first then undo the self tapping screws and pull the end cover off.
paul
Re: Heater box
Posted: Mon Aug 06, 2018 12:19 am
by Galileo
Couple of threads that come to mind and might be useful:
viewtopic.php?f=4&t=30303&start=22
viewtopic.php?f=4&t=29318
