Nut 143804 - Toledo front suspension
2door-toledo
#1 Post by 2door-toledo »
Hi,
I'm replacing all of the fasteners on my Toledo's front suspension. I'm having trouble finding a source of nut 143804 (lower right in image). Does anyone know how it differs from 143802 and if I can use this instead? 143802 is offered by certain suppliers and I believe that is a nyloc 5/16 " UNF x 1/2 ".
Thanks.
Galileo
Re: Nut 143804 - Toledo front suspension
#2 Post by Galileo »
Originally Cleveloc not Nyloc nuts to be pedantic! 3/8 UNF, have you tried looking around the Triumph range, same fasteners were used all over the place, this any good as a suggestion? https://www.revingtontr.com/product/ny6 ... 5-32-thick
2door-toledo
#3 Post by 2door-toledo »
Thanks for the reply - that's very helpful and helped me to understand that despite spending many hours looking at this page of the parts book I was misunderstanding the diagram entirely! I can now see that it goes onto the end of HB926 which as you say is 3/8" so your suggestion makes perfect sense.
Thanks!
TrustNo1
#4 Post by TrustNo1 »
Galileo wrote: Thu Sep 27, 2018 2:36 pm Originally Cleveloc not Nyloc nuts [/url]
Is there any benefit to using Cleveloc over Nylock , I've been using Nylocks since I ran out of Cleveloc?
Galileo
#5 Post by Galileo »
Only if there's any heat about, I've only ever used them on propshafts myself.
TrustNo1
#6 Post by TrustNo1 »
Galileo wrote: Thu Sep 27, 2018 8:35 pm Only if there's any heat about, I've only ever used them on propshafts myself.
Ah good point I'd not thought about heat cheers
