Stuck Sprint Spark plugs
MagentaSprint
#1 Post by MagentaSprint »
Hmmm I've no idea when the last time the plugs were taken out of my Sprint as it's been off the road for almost 30 years, I'd guess that it has been run sometime since then but who knows!!
Anyway I tried to take them out a couple of days ago and they are well tight in there, I'm in no rush to strip the threads out of the head so did not want to force them. I'm thinking from memory.....over 30 years since I've worked on this engine!!.....if I take the rocker cover off and the plug tubes I'd get near enough down to the plugs to hit them with some heat from my blow lamp? Or does anyone have any better idea's? How much force do you think the head will take before the threads come with the plugs?
dollyman
TDC Cheshire Area Organiser
Re: Stuck Sprint Spark plugs
#2 Post by dollyman »
Hi Steve, Try putting some diesel down the tubes for a week or so, that will help :D I doubt the threads will come out of the head? The worst than can happen is the plug will snap :( Then ask again, there are solutions to that.
Cheers,
PS, I know its a big distance for you, but club night is this wednesday, you will be made most welcome :D
#3 Post by xvivalve »
You’ll probably shear the plug before taking the thread...ask me how I know!
Was there any oil sitting in the plug tubes? I’ve found that can lead to the plug sitting tight...
Heat might help, as the aluminium should expand quicker, but there’s a massive heat sink in the head compared to the plug. I’d bathe them in plus-gas for a while first.
