Does anyone know of a good product to use to replicate the original sound deadening attached to the timing chain cover?
Having removed mine recently, what was left of the material just chipped off - looks a bit like bodyfiller?
I was thinking some Epoxy Mastic type putty may do the job... any ideas folks?
Kind Regards
MC
Timing chain cover sound deadening options
Matt Cotton
1980 1500HL - OPD
1976 Sprint - SWU
1980 1500HL - OPD
1976 Sprint - SWU
Re: Timing chain cover sound deadening options
The only time I have seen body/metal filler on a timing cover, someone had tried to cover a hole ?
Hi Matt, pretty much anything that will stick and add some mass will do the trick. Maybe get it nice and clean, key the surface with some coarse abrasive paper and de-grease, then use some P40 fibreglass filler to fill-in the recesses, that would do it.
Cheers Jod. Will give it a go!
Whether that big blob of BL 'cow pat' ever made much difference I don't know.
MC
Matt Cotton
1980 1500HL - OPD
1976 Sprint - SWU
1980 1500HL - OPD
1976 Sprint - SWU
Only to disguise the sound of a knackered chain I suspect!
Matt Cotton
1980 1500HL - OPD
1976 Sprint - SWU
1980 1500HL - OPD
1976 Sprint - SWU
