I’ve been tinkering on the Sprint today, time to sort the diff pinion oil seal as it has clearly been leaking for a while. Having read a few different threads on this forum on the subject I was ready for a battle with the large nut under the metal cover. To my surprise it was only just over hand tight! This Is not good news I take it? I had marked it up so that I could tighten it back to the same position. But that clearly isn’t the position it should be in!? I don’t know the condition of the diff as I haven’t driven the car so don’t know if it’s whining or similar. But I guess it must have been noisy and that the nut should be tighter?
So what to do? Tighten the nut back fully? I don’t fancy having to strip the diff out to get it set up professionally if possible. Any ideas?
Also the seal I have bought doesn’t have a backing washer on it as per the original. Is this correct to use? Photo below, old seal on the right. Do you fit the seal dry or with a little grease or hylomar?
Cheers, Bish.
