weeping sump plug
weeping sump plug
I would imagine this has been covered before but I can't find it. Done an oil change on the Toledo today and I noticed that the sump plug had been weeping, no obvious drips on the garage floor. Rightly or wrongly I wound a small amount of PTFE tape around the "outside " end of the plug threads - not run the car since. Are there any better solutions to what I think must be a commom problem? Thanks
- TDC Cheshire Area Organiser
Re: weeping sump plug
It cant be to bad a leak if there are no drops on the floor? Are you sure its not from somewhere else?
NOW A CLUB MEMBER 2017057
Yes I'm sure it is from there. I had the engine out last year and everything was cleaned well with new gaskets and seals, sad as I am I also polished the sump. There are no traces of oil running down from anywhere else but as you say it is only a slight leak.
- SprintMWU773V
- TDC Staffs Area Organiser
It's a Triumph, if it's not leaking oil, it's got no oil in it.
Very trueSprintMWU773V wrote: ↑Wed Jan 09, 2019 9:44 am It's a Triumph, if it's not leaking oil, it's got no oil in it.
I've always used PTFE on the drain plug. You did wind it on in the direction of the threads didn't you?
Its a tapered thread, so oil-tighness depends upon it being tight enough to seal but not so tight that it knackers the threads and / or taper. Almost all I've ever seen (lots) have been overtightened at some point, I think its because folk don't like the last few threads showing....
That's a good point, my threads look fine and there certainly is and has had threads still showing.
- NickMorgan
Strange. The sump plus is about the only place I have never had a leak on one of my Triumphs!
Thanks Photobucket
