Hi
When I have the fanr on in my car, alot of air comes out via the controls, is the normal, or is there a seal that's goosed?
I dont want to start ripping the dash apart, As i only got my car back on the road!
Regards
Barry
Dolomite 1500 TC - Lot of hot air from the controls
Aberdeen
Re: Dolomite 1500 TC - Lot of hot air from the controls
assuming its only when set to hot and not cold and you mean the hot air comes out by the controls instead of the vents, if so then the vent from heater box is damaged/ missing/ blocked or the foam seal is missing.
Hi
Thanks, looking at drawing it looks like I am going to have to remove the heater and replace the seal, Bugger!
Regards
Barry
Regards
Barry
Aberdeen
