Remote reservoir clutch cylinder feed
#1 Post by xvivalve »
There will be those amongst us who have experience of this problem; the steel union corrodes and binds with the steel pipe which feeds the clutch master cylinder, meaning the pipe either shears, or the cylinder has to be removed from the bulkhead in order to retrieve the pipe intact. Like this:
Annoying, isn’t it?
Re: Remote reservoir clutch cylinder feed
#2 Post by xvivalve »
Well, solution is at hand:
Copper pipe, brass union, brass olive at top end
£15.00 inc UK delivery
Jod Clark
#3 Post by Jod Clark »
:thumbsup: Cracking job sir. UK made I hope!
#4 Post by xvivalve »
Jod Clark wrote: Wed Jan 23, 2019 4:47 pm :thumbsup: Cracking job sir. UK made I hope!
Absolutely, with Yorkshire copper too!
PaulB
#5 Post by PaulB »
Hi Alun,
Will we be able to purchase these at Stoneleigh? I also want some 1 3/4 solid carb mounts?
Regards, Paul.
#6 Post by xvivalve »
Hi Paul, on the former, only if I see someone who is going prior, as I’ll be in Austria skiing, the first Triumph Show that I’ll miss in 27 or 28 years. The latter will rely on whether Martin is going or not, as he’s the keeper of those...
Alun
DavePoth
#7 Post by DavePoth »
Another shiny thing to add to the list - I cobbled something together using extra hose and many jubilee clips but it's not pretty.
