Toledo vs dolomite rear wing
Albuzz
#1 Post by Albuzz »
Hi, does anyone know if the rear wheel arch part of the rear winch has the same profile (wheel arch shape/radius suage lines etc.? So that it could be used as a reoair panel. My guess is that it is the same since I think the suage lines are the same. Thanks Alan
DOLOMITE 135
Re: Toledo vs dolomite rear wing
#2 Post by DOLOMITE 135 »
I'm not sure if you mean to use a Dolomite repair panel on a Toledo or visa versa, but the swage lines differ between Toledo and Dolomite rear wings. Using a (now rare) Dolomite repair panel on a Toledo would end up looking rather odd, and cutting up a Toledo wing to fit on a Dolomite would also look wrong.
It's probably better to use the club wheel arch repair panels for the appropriate model, than modify an incorrect panel.
As an example I placed one of my (non club) Dolomite rear wheel arch repair panels against my Toledo as shown below, it looks wrong in my opinion.
ragtop
#3 Post by ragtop »
The Rear Wings Are Differant. The Toledo is The Same as a Triumph 1300 FWD
1972 Triumph Toledo PKS 379L Emerald green
1974 Triumph Stag
1993 Vauxhall Corsa Died now growing flowers in it
11 Vintage Tractors
2007 Isuzu Rodeo
