Gearbox leaks
white dolly sprint
Gearbox leaks
#1 Post by white dolly sprint »
Hi
I have a few small oil weeps of oil on the gearbox of the sprint. I have seen that winns do a gearbox stop leak which swells the oil seal to stop small leaks. Has anyone used this in an overdrive gearbox and had any problems with the overdrive at all.
Mike.
Re: Gearbox leaks
#2 Post by soe8m »
Those stop oil leak additives all work as promised. Your gearbox will leak less oil but will start leaking a bit stop leak additive now.
So your oil leaking will be reduced but the overall leakage in cc's/mile or cc's/week will not reduce by the usage of these additives.
cleverusername
Re: Gearbox leaks
#3 Post by cleverusername »
soe8m wrote: Sun Mar 10, 2019 9:36 am Those stop oil leak additives all work as promised. Your gearbox will leak less oil but will start leaking a bit stop leak additive now.
It depends why it is leaking. There are different sorts of stop leak. For example the sort you throw in a cooling system generally contains particles that clogged up the leak. The sort you are referring to work by swelling tried seals. I have used that sort in a power steering system and it worked well
The problems I can see, is it depends where the leak is coming from. That kind of stop leak will be no good for a paper gasket.
Does the OP know the source of the leak?
white dolly sprint
Re: Gearbox leaks
#4 Post by white dolly sprint »
Hi thanks for the replys.
Was wondering if any of the stop leaks and gearbox treatments would effect the operation of the overdrive.
Has anyone used them in a overdrive.
Mike.
