A matter of opinion!
#1 Post by Carledo »
Having finally got the Dolomega's engine settled firmly on its mounts, i've refitted the front panelling and bonnet to the body to check clearances.
An initial try fit a few months ago, led me to think that I would need an extra 1/2" above the cam belt cover, so I got this rather fetching T1300FWD bonnet bulge to set into my bonnet and solve this problem with style (Thanks, Bruce!)
However, yesterdays real world test shows that I can get away with it by 3/8" (and torque reaction takes the cover AWAY from the bonnet at this point)
So do I fit it anyway, or keep the bonnet stock? What's YOUR opinion? (not that I promise to abide by it!)
new to this
Re: A matter of opinion!
#2 Post by new to this »
I would keep the bonnet as standard ,or fit air vents like RS Turbo
#3 Post by Carledo »
I quite like louvres, lots of louvres! But they're expensive to have cut in, awkward to paint successfully and being fuel injected, the engine doesn't need them! The same applies to tacky aftermarket panel vents but even more so!
The pipe feeding the vertical throttle body is also VERY close to the bonnet, i've had to cut a section of the inner bonnet web away to clear it. The possibility exists to put an extra, offset, teardrop TR4 style bulge over that, rather than the centre one which really isn't needed. That might look good too! (but not both)
Bish
#4 Post by Bish »
I like it. It looks mean, and suggests there’s something unusual under there.
Good work.
Triumph1300
#5 Post by Triumph1300 »
Do it!!!
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
dollyman
TDC Cheshire Area Organiser
#6 Post by dollyman »
I like it Steve :D I would keep it, if only to keep people guessing :lol:
#7 Post by xvivalve »
Do it.
red&black
#8 Post by red&black »
If the rest of the body is going to be standard,I'd keep the bonnet that way.
I suspect it will be having at least larger than standard wheels though-and probably other modifications. If this is the case then my advice would be do it.
James
shaunroche
#9 Post by shaunroche »
It's a No from me! Standard all the way!
oily66
#10 Post by oily66 »
dollyman wrote: Tue Apr 09, 2019 10:31 am I like it Steve :D I would keep it, if only to keep people guessing :lol:
Second that one, if you want to be stopped to answer their questions.
Trevor
2017 Jaguar XE R-sport
going_downhill
#11 Post by going_downhill »
Standard. Go for the sleeper effect.
1980 Russet 1850hl
#12 Post by tony g »
I like it. If you dont use it can I have it off you? :)
#13 Post by Carledo »
tony g wrote: Sat Apr 13, 2019 11:14 pm I like it. If you dont use it can I have it off you? :)
Sure Tony, you get first refusal! I do like it, but i'm leaning towards the (actually functional) teardrop bulge over the intake pipe and the 2 would compete for position! I just need to find a suitable bulge, without having to cut one out of a (doubtless expensive) TR4 bonnet!
#14 Post by tony g »
:thumbsup: :-D
Carledo wrote: Mon Apr 15, 2019 12:36 am
NickMorgan
#15 Post by NickMorgan »
Yes, go for it. I think I would make it a little deeper if it was mine!! And normally I don't like straying away from standard!!
Image Thanks Photobucket :(
