Where's this bit go?
GrahamFountain
#1 Post by GrahamFountain »
I know it's a front mudshield, but I can't see a space this shape anywhere.
Also, any ideas where I can get the other side one or better still full wheelarch inserts. I don't mine sawing down to size.
Ron1966
Re: Where's this bit go?
#2 Post by Ron1966 »
It is a mud shield Graham and that one is the nearside one, it fits across the inner wing reinforcer held on with two plastic pins. It stops mud and crap forming on top of the ledge.
GrahamFountain
#3 Post by GrahamFountain »
Pretend I don't know anything and you won't be far off.
Ron1966 wrote: Mon Apr 22, 2019 1:44 pm inner wing reinforcer
What do the pins go into?
#4 Post by Carledo »
GrahamFountain wrote: Mon Apr 22, 2019 2:34 pm Pretend I don't know anything and you won't be far off.
OK, look up inside the front wheel arch, aft of the suspension leg. Right at the top, you will see a triangular section starting about 4" wide at the bulkhead and tapering down to nothing around the top suspension mount. This is the strut/iner wing reinforcer. You may not be able to see, but if you feel up the vertical face of this panel you will find 2 holes that the clips go into to hold the plastic guard on. If you feel right up to the top of the vertical face, you will feel a gapwhere the reinforcer returns to the flitch. it's probably too small to actually get you finger between the reinforcer and the underside of the wing, but dirt and road muck can gather there and rot the reinforcer out, like this :-
Bradman
#5 Post by Bradman »
My MK1 Escort had a shelf like that on the inner wings - not for strength, just designed obsolescence! They even had a dish shape to ensure water stayed put :shock: I ground those suckers of when I replaced the wings... Don’t grind off those on the Dolly though, they really are structural...
Bradman.
Current classic cars: 1974 Triumph Dolomite (Honey), 1978 Triumph Dolomite Sprint (Holly), 1974 Triumph Spitfire 1500 (Pepper)
Current modern cars: 2010 Mini One (Rusty), 2019 BMW i3 (Treehugger)
Past cars: 2003 BMW Z4 roadster 3.0 (Marty), 1972 Triumph Spitfire IV with 2.0 I6 (Polly), 1972 Ford Escort 1100L with RS2000 running gear (Nora Batty)
GrahamFountain
#6 Post by GrahamFountain »
Carledo wrote: Mon Apr 22, 2019 9:24 pm
Ah, the pictures from Rimmers suggested it's orientation was a bit different. I've been looking at totally the wrong end of the wheel arch and the wrong way round.
GrahamFountain
#7 Post by GrahamFountain »
Oh there! Though if I said I see where it fits now, it would be a very loose use of the word "fits" indeed.
Are the pins like the front mud shield ones?
#8 Post by Carledo »
Pins are ZKC 1275. They must be used somewhere else as well, as the parts book says there are 10 (to do both sides)
But not on the front shield behind the headlight as those clips are a different part number, ZKC 511 (x6)
Fit is indeed a misnomer. one or two of us are looking for a more complete (in every sense) solution by adapting a modern style full arch protector to suit the Dolomite. Saab 9-3 seems to be favourite so far.
Richard the old one
#9 Post by Richard the old one »
I am almost certain that on my 1977 and later dolomites that the pins that hold the front shield and this mud shield are the same.
#10 Post by Carledo »
Richard the old one wrote: Wed Apr 24, 2019 1:42 am I am almost certain that on my 1977 and later dolomites that the pins that hold the front shield and this mud shield are the same.
Part numbers were taken from my Sept 75 Sprint parts list, my first thought was that they are all the same clip too, but I wasn't sure so I looked it up!
GrahamFountain
#11 Post by GrahamFountain »
I may have a SH set of the top mud shields and pins on the way, possibly.
Carledo wrote: Wed Apr 24, 2019 1:00 am Saab 9-3 seems to be favourite so far.
Looks like they need a lot of cutting, but an interesting idea. Especially, interesting wrt the front light area, which was all rotted out before.
There looks to be a delay ahead while it goes back to raining, so I might think about that.
