I have obtained a pair of ST 2" carbs ( FZX1050 ) and am doing a refurb before using them. They are exactly as per the original SU FZX1050 diagrams with the UP needles but I need a 0.125" jet ( CUD2697 ) for the front carb because that one has a broken feed pipe. Burlen currently have them on back order.
Any thoughts or recommendations about using them on the Sprint engine? Cleaned up head with a Newman phase 3 cam and a balanced bottom end.
Sprint 2" SU HS8 carbs
Russ Cooper
Dursley
UK
Dursley
UK
- gmsclassics
Re: Sprint 2" SU HS8 carbs
I inherited a pair, complete with manifold from a crashed car that was used for mild motorsport. I then fitted them to a road going Sprint with a standard to mild cam. Yes, the car went really well at higher revs and illegal speeds, but I soon removed and went back to the standard carbs as the engine lost much of it's low speed torque and overall tractability. Generally it was a pain to drive in town or slow traffic and even on the open road required more gear changes to get higher revs where the performance was. Fine if you want it for a track capable car and are happy to put up with a more difficult drive around town.
So answer really depends on what you want to use the car for....
Geoff
Geoff
