Weber DCOE 45’s idle speed adjustment
Posted: Sun Jul 28, 2019 6:02 pm
by storeyn
Hi All
Is the only way to adjust the idle speed on Weber 45’s to adjust the idle mixture screws? Tickover at the moment is around 1100 rpm. I would ideally like to get it a bit lower.
Any advice would be most grateful
Nigel
Re: Weber DCOE 45’s idle speed adjustment
Posted: Sun Jul 28, 2019 6:13 pm
by soe8m
storeyn wrote: Sun Jul 28, 2019 6:02 pm Hi All
Nigel
The idle mixture screws are for setting the idle and lower revs mixture. The idle revs are adjusted by the throttlevalve screws like SU's.
Posted: Sun Aug 04, 2019 8:08 pm
by storeyn
Thanks Jeroen
After a bit more investigation looks like the return springs are not returning the throttle linkage to the correct position and holding the revs up.
New springs ordered :D
Nigel
Posted: Mon Aug 05, 2019 5:51 pm
by dursley92
storeyn wrote: Sun Aug 04, 2019 8:08 pm Thanks Jeroen
Nigel
Make sure its the springs and not something else stopping them closing properly. Like a butterfly moved etc
Posted: Wed Aug 28, 2019 4:14 pm
by storeyn
Thanks all for the advice..after a bit of tweaking idle speed spot on...
Completed a track day and the car went very well.....
