Sprint vs non-Sprint servo
RichardHyde
#1 Post by RichardHyde »
Evening all,
I’m planning to use a Sprint axle with Trackerjeck front brakes and a tandem master cylinder.
I’ve got a Sprint and non-Sprint servo, but space is at a premium.
Will I feel much difference between the two servos ?
Thanks, Richard
Re: Sprint vs non-Sprint servo
#2 Post by xvivalve »
Latterly, all models were superseded in the aftermarket catalogues with just a single servo type, and it wasn’t the original Sprint one.
I challenged JCL Spares at one of the autojumbles on this matter as he was displaying a servo labelled up as Dolomite Sprint which didn’t resemble a Sprint item, being both shallower, smaller diameter and with the one way valve in a different place to the normal 11 o’ clock. He promptly produced a 1990’s catalogue and cross referred the servo to the whole Dolomite range model by model including the Sprint.
I suspect there will be a slight difference in pedal feel, but to what extend I couldn’t predict.
Hmm......
#3 Post by sprint95m »
Given how much more braking you will have with the Ford calipers and vented discs,
if it was up to me, I would not fit a servo and see how that does.
That way you save both space and weight.
#4 Post by Carledo »
I have run the Carledo on both a Sprint servo and an 1850 one.
The Sprint servo failed and this was before the club started (or restarted) doing recon ones, so Sprint servos were like expensive hens teeth, to get the car back on the road quickly and cheaply, I fitted an 1850 servo as a temporary measure - and it's still there as I found I liked it better that way! I also have TJ brakes and a very light body. With the 1850 servo, the pedal loadings are very slightly higher, but there seems to me to be a lot more "feel" to it.
cleverusername
#5 Post by cleverusername »
Carledo wrote: Tue Jan 14, 2020 9:12 pm I have run the Carledo on both a Sprint servo and an 1850 one.
I've always wondered about feel, whether that is really just a code for heavy. The only car I have ever driven without power assisted steering is the Dolomite, I can't say I found any superior to the power assisted cars I am use to.
As for brakes, my father will complain that brakes are wooded or over servoed, whereas they feel OK to me. It is noticeable that he tends to use allot more force on the brake pedal, having learnt to drive in the 60's.
Of course I have never driven on a track and I don't take cars anywhere near their limits.
#6 Post by Carledo »
cleverusername wrote: Thu Jan 16, 2020 6:27 pm
"Feel" is the distance in the pedal travel between light check braking and emergency stop!
Too many modern cars are thoroughly OVERbraked (because with ABS, you can get away with it) with a brake pedal that is more like an on/off switch, which makes you grateful for the seatbelt when you breathe a bit too hard on the pedal!
I pride myself on driving smoothly (as well as quickly) and a braking system with a good feel, one where you can press lightly to brake lightly or press harder to stop quicker and you can FEEL the amount of work you are doing to achieve this, is a real advantage.
I too learned to drive in the 60s when nothing much had power steering or even servoed brakes. I had a number of 2.5 litre 6 cylinder, 6 seater Ford Zodiac mkIIs that had neither and didn't need them. And they were a large car in their day! But driving a car like that took skills that most youngsters these days couldn't cope with bothering to learn. Double declutching, for example, if you can do that, you can continue to drive a car when the clutch activation mechanism (cable or hydraulic) has failed. nowadays one just gets on the mobile phone and calls Green Flag or whoever. I have had some spectacular car failures in my life and ALWAYS got home, I once drove most of the way from Liverpool to London in an MG 1100 that had a broken crankshaft! The only time I've EVER called the AA was to a nearly new Metro that wasn't mine. Since it was under warranty and the warranty included AA cover, why not?
cleverusername
#7 Post by cleverusername »
Exactly the complaint my father makes, that the brake is an on/off switch. However it doesn't feel that way to me in a modern car, I am use to cars with allot of power assistance, so it is noticeable I use allot less force when braking than he does.
Give me an older car without a servo and drum brakes, I would probably end up in a ditch, tree or other hazard before I could get it to stop.
#8 Post by Carledo »
cleverusername wrote: Thu Jan 16, 2020 10:50 pm
Your dad is right!
And it's not your fault that you had the misfortune to be born a generation too late to be taught to drive properly on a proper car that doesn't do everything but change your nappies for you!
Your dad and I were taught to use the gearbox to slow down, because brakes couldn't be trusted, we were taught cadence braking because ABS didn't exist. We were taught skid control, to drive "by the seat of your pants", double declutching and a myriad of other skills that modern cars have made obsolete. This is called progress and though I have learned to live with it, I don't have to like it!
What I find totally unforgiveable about modern cars is the way they isolate the driver from any sense of connection with the car, it's no longer possible to be "man and machine in perfect harmony" as one old adveritising slogan claimed, because you can't TELL what's going on under your bum anymore! It's why I love driving old cars and regard modern stuff as "white goods"
As a professional spannerman, I am in and out of moderns and classics all day long and it no longer bothers me to swap from one to the other, you just have to keep in mind what you are driving! Fortunately, the seat of my pants still works, if it's recieving signals, my hindbrain understands that I am in a classic car and drives accordingly. If there are NO signals, it goes to sleep and engages the autopilot!
bazyerma
#9 Post by bazyerma »
Carledo wrote: Thu Jan 16, 2020 11:51 pm
Your dad is right!
Point made, young people have it to easy, blah blah bah! :roll: :wink: :D
Although I don't quite qualify as a Millennial at 35, I have still driven my 1991 ford Orion from Glasgow to Aberdeen with a bent steering rack, My 1988 Audi 90 Back from Edinburgh with a leaking heater matrix by passed with a coke bottle neck and the coolant system filled with cola, and Most recently, my Triumph back from Perth with no clutch, and dyeing battery!
Remember, it was you and your Kids that invented and implement all these things, I was just unlucky enough to be born into it :mrgreen: !
Regards
Barry
Aberdeen
#10 Post by Carledo »
Barry, I had no wish to offend anyone with my remarks, my criticisms are levelled more at the manufacturers who make cars SO easy to drive that it no longer requires concentration to do it and SO insulated from the road that the driver can't feel, instinctively, that something is wrong.
It's also obvious to me that you feel the same, as whilst you mainly seem to drive cars that are not as old as mine, (with the exception of the Triumph of course) they are still not what I would describe as moderns. Bearing in mind the age difference between us, it's likely that my Zodiacs and 1100s were about the same age when I had them as your Orion and Audi were when you owned them, if you see what I mean. It's only really since around 2000 that cars have lost their way so badly.
I do actually own a car that I describe as modern, a 2006 Xsara Picasso, but it's just a tool for a job, which, to be fair to it, it does admirably and without fuss or excessive cost. But I don't and never COULD love it!
bazyerma
#11 Post by bazyerma »
Carledo wrote: Fri Jan 17, 2020 11:35 am Barry, I had no wish to offend anyone with my remarks, my criticisms are levelled more at the manufacturers who make cars SO easy to drive that it no longer requires concentration to do it and SO insulated from the road that the driver can't feel, instinctively, that something is wrong.
The Simile faces were my way of showing I was not insulted or offended, Don't believe everything you ready about us snowflakes, but I do get feed up of being told how easy we have it! :mrgreen: :lol: :lol:
When it comes to my most modern (2019 Mitsubishi Eclipes Cross 1.5turbo 4x4) its amazing how easy it is to drive, with all the bells and whistles on it, and warning binges, you could drive it blind!
Regards
Barry
Aberdeen
cleverusername
#12 Post by cleverusername »
I think it depends what you're using it for. For my daily commute I want a car that is easy to use, so give me power assisted everything and a car which will start first time every time.
If I want a car drive for pleasure, then I want something different. However my complaint about modern cars isn't the power assisted steering or brakes. I don't mind them. The problem in my opinion is power, modern cars simply have too much of it.
Take the XF a member of the family owns. It is very impressive for the 1/2 second or so you can accelerate but then the driver has stop because of a speed limit, bend or other hazard. There is no way to enjoy such a car safely and legally on a public road.
A car with a fraction of the power is much more fun. We have a knackered MGF, not really very fast but it makes a nice noise and you can keep your foot on the loud pedal for a decent amount of time and still be under the limit.
Basically what I am saying is I don't need a car which can do 150mph and has a ludicrous 0-60 time. To get that kind of performance means added weight and makes it dull to drive on a public road.
