Vin / Chassis plates
Replacement Vin plates /Chassis plates are they still available NOS or Remanufactured , if so where from please.
1973 yellow Sprint L reg
1979 1500 SE T reg
1979 1500 SE V reg
1980 vermillion 1500hl W reg
1975 green 1500tc auto P reg
1973 Brown Toledo 2 dr L reg
1973 Green Toledo 2 dr L reg
1983 White Toyota Tercel 4x4
1987 Brown Toyota Tercel 4x4
1988 Blue Toyota Tercel 4x4
1999 Toyota Corolla vvti est
2005 Ford ranger thunder XLT
1979 1500 SE T reg
1979 1500 SE V reg
Re: Vin / Chassis plates
I have early style in Kgs and late style for Sprint, Mike Barker has early style in lbs
I need one for my 1500 se as the rivits rotted through and it fell down behind my battery so i put it somewhere safe years ago and cannot remember where, i wasn't in the best condition from what remember.
1979 1500 SE T reg
1979 1500 SE V reg
1979 1500 SE T reg
1979 1500 SE V reg
Alun do you know if the ones you have will be for the 1500se , are the NOS or remanufactured and how much please
also do you do the stamping for them ?
thanks
steve
1979 1500 SE T reg
1979 1500 SE V reg
1979 1500 SE T reg
1979 1500 SE V reg
Hi Steve, the weights will be different for an SE; both mine and Mike’s are reproduction.
They are a tenner including postage.
I can do the stamping, yes, but I’m not that practiced!
Ok i will look out for the ones with the correct weights on thanks.
steve
1979 1500 SE T reg
1979 1500 SE V reg
1979 1500 SE T reg
1979 1500 SE V reg
- Len Hughes
Hi Alun,
That should be spot on then, my original BL one was all over the place
1973 Mimosa Sprint
1973 Magenta TR6
1973 Magenta TR6
