B post trim
new to this
B post trim
#1 Post by new to this »
Are the B post trims glued to the head linning ? Tiring to remove mine
Re: B post trim
#2 Post by Carledo »
I don't think so, or, if they are, only about 1/2" or less. To get the B pillar trims off, remove the furflex from the appropriate bit of both door openings, unbolt and remove the seatbelt and carefully tease off the bits wrapped and glued round the door gaps. A little heat, ie hairdryer, helps here. And that's it!
new to this
Re: B post trim
#3 Post by new to this »
Carledo wrote: Wed Mar 04, 2020 8:58 pm I don't think so, or, if they are, only about 1/2" or less. To get the B pillar trims off, remove the furflex from the appropriate bit of both door openings, unbolt and remove the seatbelt and carefully tease off the bits wrapped and glued round the door gaps. A little heat, ie hairdryer, helps here. And that's it!
thanks got it off today,i originally thought it was just the bottom half that come apart
Thanks Dave
new to this
Re: B post trim
#4 Post by new to this »
Any one recovered a B post trim ?
oily66
Re: B post trim
#5 Post by oily66 »
Available new from Aldridge’s
Trevor
2017 Jaguar XE R-sport
