B post trim
Posted: Wed Mar 04, 2020 8:40 pm
by new to this
Are the B post trims glued to the head linning ? Tiring to remove mine
Re: B post trim
Posted: Wed Mar 04, 2020 8:58 pm
I don't think so, or, if they are, only about 1/2" or less. To get the B pillar trims off, remove the furflex from the appropriate bit of both door openings, unbolt and remove the seatbelt and carefully tease off the bits wrapped and glued round the door gaps. A little heat, ie hairdryer, helps here. And that's it!
Re: B post trim
Posted: Thu Mar 05, 2020 9:19 pm
by new to this
Carledo wrote: Wed Mar 04, 2020 8:58 pm I don't think so, or, if they are, only about 1/2" or less. To get the B pillar trims off, remove the furflex from the appropriate bit of both door openings, unbolt and remove the seatbelt and carefully tease off the bits wrapped and glued round the door gaps. A little heat, ie hairdryer, helps here. And that's it!
thanks got it off today,i originally thought it was just the bottom half that come apart
Thanks Dave
Re: B post trim
Posted: Fri Mar 06, 2020 8:54 pm
by new to this
Any one recovered a B post trim ?
Re: B post trim
Posted: Fri Mar 06, 2020 10:28 pm
by oily66
Available new from Aldridge’s
