Adjustable steering column
Steve28
#1 Post by Steve28 »
Hi all, Will a adjustable steering column fit into a 1500SE ( flat plank dash)
if not a straight swap will it ft with a few tweaks ?
1973 yellow Sprint L reg
1979 1500 SE T reg
1979 1500 SE V reg
1980 vermillion 1500hl W reg
1975 green 1500tc auto P reg
1973 Brown Toledo 2 dr L reg
1973 Green Toledo 2 dr L reg
1983 White Toyota Tercel 4x4
1987 Brown Toyota Tercel 4x4
1988 Blue Toyota Tercel 4x4
1999 Toyota Corolla vvti est
2005 Ford ranger thunder XLT
Re: Adjustable steering column
#2 Post by Carledo »
Yes, I've done it on Andy's SE. And the plank dashed Carledo.
You need the hanger bracket and double jointed fingers to fit the bolts at the top without pulling the entire dash out and you need longer bolts and about 1/2" spacers between the column bracket and the bottom rear of dash. that's about it!
