Does anybody know the part number for the clips that attach the back chrome trim on a early 1850. It's the chrome that looks like a hockey stick that goes from the top of the wing and then halfway along the length of the boot and is then joined by a 1 inch joining piece to the next.
Looking on the web I can find a similar clip but not the same as mine.
I also need clips for the sill chrome but looking on this forum I have found a part number 629647 which seems correct on Bresco web page.
Alan
Trim part number please
Re: Trim part number please
There are 2 different clips for this trim, a metal clip (4x627362) that go at the top and a plastic one (14x 630534) that the first one is just into the vertical section and the rest across the bottom. A couple at the ends each side are held on with an additional pop rivet.
These numbers taken for a 1975 Sprint parts list, but the series 1 Sprint bits will be the same as your early 1850.
HTH, Steve
HTH, Steve
- yorkshire_spam
Bresco linkeyCarledo wrote: ↑Sat Jun 06, 2020 10:21 pm There are 2 different clips for this trim, a metal clip (4x627362) that go at the top and a plastic one (14x 630534) that the first one is just into the vertical section and the rest across the bottom. A couple at the ends each side are held on with an additional pop rivet.
HTH, Steve
