1) June: Uneven Negative Camber: Feels like Pointy steering but vague around the centre
Camber -0.49’ -2.03’
Caster Not measured Not measured
Toe +0.02’ +0.05’
2) After playing with suspension height (raising it from lowered)
August: Uneven Negative Camber: Feels like Pointy steering but very vague around the centre. This is horrible
Camber -0.54’ -1.29’
Caster +0.59’ +0.02’
Toe -0.13’ -0.15’
3) After adding shims for camber
October (today): Neutral Camber: Feels like very dull, not at all pointy but much less vague at centre
Camber +0.22’ +0.15’
Caster +1.31’ +0.24’
Toe +0.10’ +0.09’
I am looking for pointy (for road rally tests) but without the disturbing vagueness at centre (by which I mean a fair bit of play around the centre before any action)
I am confident that there is no play in the UJs (I have upper and lower UJs). Ball joints and tie rod ends recently replaced. Poly bushes all around including steering rack mounts. I can see that I might need the sprint speed adjustable tie rods for the castor but feel that maybe I can reach a desired compromise in the meantime.
I would welcome some advice on which direction to go! arf arf
Quentin
