1975 1500TC rear disc conversion - NOW ROAD TESTED!
bazyerma
#1 Post by bazyerma »
Hi
On stripping my rear axel for new bearings, seals and a freshen up I decided to fit rear discs.
**At this point please take note before commenting, I have not tested these on the road yet *Now tested 09/05/21 - Success!*, and I am aware many will know this is a pointless / un-necessary modification, but I wanted to do it, so that’s reason enough for me (and it was fun!) **
Planning phase
In the past I had butchered my backing plates to fit MG TF wheel studs, as I am running MG wheels (drilled a hold in them so I could fit them without taking out the half shafts as I could not remove the hub) so I wanted to replace them and clean up my drums.
On strip down I found both rear cylinders were leaking, and the drums and shoes were worn and could not re-used. I estimated the cost of replacing the lots at approx. £220 so although rear discs would cost more than this, at least I had a cost to compare to! EG - Shoes - £20, Drums - £110, Cylinders - £40, Back plates - £20, Clips / Pins / retaining kits - £30
Plan – Due to the use of MG TF studs and knowing the PCD is the same I decided to go with MG TF discs, calipers and hoses, with a bracket to fit them to the axel bolts.
FITTING
Back plate
With the axel stripped and new bearings on the has shaft, the first modification I did was using the grease catcher (104582) as a template I marked the outline on the backing plate and cut out the centre to size (you could make this from 2mm plate if your back plates are worth saving or going back to stock). With this fitted I put everything on the axel together ready to make up bracket
back plate fitted without disc.jpg (162.36 KiB) Viewed 3602 times
back plate cut and fitted with disc.jpg (162.23 KiB) Viewed 3602 times
Back plate template.jpg (235.88 KiB) Viewed 3602 times
Aberdeen
bazyerma
Re: 1975 1500TC rear disc conversion
#2 Post by bazyerma »
Discs
Trail fitting the discs I found the drives size fitted but the passenger side was catching the hub. 2 minutes with the file removing the casing marks on the hubs and it fitted.
**IMPORTANT – as per the photos show, the disc centre hole is larger than the lugs (spigot) of the hub, and therefor the discs are only centred on the wheel studs, and disc retainer bolts cannot be fitted. I am happy with the centerisation of the disc and the run out, but I have not had a road tested yet, and I am sure plenty of engineers would not be happy either. **
Bracket
Using a large nut on the wheel studs with the wheel nuts I fitted the disc, then holding the caliper with pads in place I made a carboard template to suit the 70mm od of the axel tube spacing to match the caliper carrier. When drawing up the bracket in paint I extended the legs 10mm with the radius of the curve continuing to help it “hook” into place.
I decided to make the bracket out of 8mm plate as the flange on the axel is approx 5mm and the carrier is 12mm so I decided 8mm would be strong enough.
The drawing was sent to a local machine shop with a water jetting machine and they turned it round in 2 days for £40. There is online companies but they needed a proper drawing, Cad ect but the shop local to me did the drawing ect.
Trail fitting the bracket it was tight, so I filed down the bottom leg flat and it went on with a nice tight fit. I measured up for the bolt holds and drilled out the axel size to 8.5mm and the caliper side 11mm.
Caliper in position to make carboard template
Caliper trail fit.jpg (217.25 KiB) Viewed 3599 times
Template
Template
Carboard template with extra 10mm.jpg (124.08 KiB) Viewed 3599 times
Disc to spigot
Disc to spigot
Disc to spigot.jpg (173.11 KiB) Viewed 3599 times
Aberdeen
bazyerma
#3 Post by bazyerma »
Build
The brackets are fitted with the centre line matching the weld across the axel tube with two of axel flange bolt holes using M8x40mm high tensile bolts.
Calipers are fitted onto the bracket via M12x1.5mm BMW caliper bolts I had, but I think MG part number is BAU5631.
Brake hoses
For the hoses and lines, my car is a single line to the rear with a flex over the axle. I have used MG TF hoses, linked via a M10 3 way splitter with 5 male M10 fitting, then a cross over pipe to the correct 3/8in female fitting with 3/16in copper pipe.
PHOTO / Sketch
Handbrake (work in progress)
The plan was to try something with MG TF cables, but it looks like I can use the standard cables, with the caliper hand brake arm hole drilled out to 6.5mm to accept the original pin.
Dodge handbrake
Dodge handbrake
Hand brake first attempt.jpg (355.25 KiB) Viewed 3598 times
Finished, sort of
Finished, sort of
Axel fitted to car with caliper.jpg (163.19 KiB) Viewed 3599 times
Axel fitted with the brackets to car
Axel fitted to car with bracket.jpg (224.46 KiB) Viewed 3599 times
Placement of Tee
Placement of Tee
Tee fitted.jpg (296.63 KiB) Viewed 3599 times
MG hoses and fittings
MG hoses, fittings and pipe.jpg (215.41 KiB) Viewed 3599 times
First fit
First fit
Bracket trail fit.jpg (144.03 KiB) Viewed 3599 times
bracket fitted
bracket fitted
Bracket driled and fitted - Side.jpg (245.62 KiB) Viewed 3599 times
Brackets with templates.jpg (121.67 KiB) Viewed 3599 times
Aberdeen
bazyerma
#4 Post by bazyerma »
TESTING
Now the car is still awaiting a refurbished cylinder head, so this is still untested (all just prototype stage!).
As brake down of the costs to me are approx. £300 with all new parts. I already had MG TF wheels and studs fitted so take that into account as it will add to the costs.
Calipers with pads and carriers - £170
Brackets - £40
Hoses - £25
Discs - £30
Bolts, pipe fitting ect - £35
WEIGHT
As per attached photos my disc conversion added an extra 5.4Kg to the rear axle weight.
Parts list
Rimmers links but it’s a lot cheaper to shop around, and get the calipers with carriers
MG wheel Studs – RB FAM8419K16 / eBay - FAM8419 - £66 for 16
https://rimmerbros.com/Item--i-FAM8419K16
MG wheel Nuts – RB NAM9077P1 / eBay NAM9077 - £96
https://rimmerbros.com/Item--i-NAM9077P1
MG Rear discs – RB SDB100461 - £55 pair
https://rimmerbros.com/Item--i-SDB100461
MG Rear Caliper – Right (SMC000460) and left (SMC000470)
https://rimmerbros.com/Item--i-SMC000460
https://rimmerbros.com/Item--i-SMC000470R
MG rear caliper carrier – Right (SXP000070) and left (SXP000060)
https://rimmerbros.com/Item--i-SXP000070
https://rimmerbros.com/Item--i-SXP000060
MG Rear Caliper Mounting Bolt – RB EJP6293 x 4 £8
https://rimmerbros.com/Item--i-EJP6293
MG rear hose RB SHB000880 £18 x 2
https://rimmerbros.com/Item--i-SHB000880
M10 female Brake hose Tee – eBay example
https://www.ebay.co.uk/itm/Female-brass ... xy07FRjG3n
Fitted, befor fitting to the car
Caliper fitted - Side.jpg (167.99 KiB) Viewed 3598 times
Disc
Disc
Caliper weight.jpg (191.97 KiB) Viewed 3598 times
Drum
Drum
Drum weight.jpg (153.21 KiB) Viewed 3598 times
Aberdeen
new to this
#5 Post by new to this »
Nice mod,i used rover 45 brake calipers
bazyerma
#6 Post by bazyerma »
Hi Dave
That's some nice looking brackets, I am tempted to make back plates after I have test everything.
Regards
Barry
Aberdeen
new to this
#7 Post by new to this »
hi barry
have you upgraded the front brakes ? what style/type of MG wheels are you using
#8 Post by Carledo »
I was gonna say much the same thing, but Dave beat me to it above^^^^
I would think you need a TJ kit up front (if you don't have one already) either that or some sort of pressure limiter for those rear calipers, otherwise your front/rear bias will be all to cock!
I ran an unlimited Sprint rear setup on the Carledo briefly, it's propensity to change ends under heavy braking was disturbing, to put it mildly! A Cavalier pressure limiting valve fixed that until I could afford the TJs.
Latham_F2
#9 Post by Latham_F2 »
That looks very similar to the setup I ended up with during first lockdown.
I used a pair of new Renault Scenic calipers, bought a while ago from Ebay for about £35(!) after using an online brake bias calculator to work out a suitable piston diameter to avoid overbraking the rear.
Since I'm already running 6R4 4pot calipers on the front, these were fine.
The front will be getting Wilwood calipers soon anyway.
Main difference seems to be that I picked up on 5 of the 6 axle flange bolts.
This did mean that I was limited on where I could put the caliper, because the gap also has to avoid the grease nipple on the back.
I also found out the reason why my brakes were so crap - turns out both axle seals had been leaking.
Not enough to be obvious, but boy did the shoes stink of oil!
Fixed that using the gearbox seal mod recommended on this forum.
Like yourself, I haven't had chance to try them out on the road.
But a quick run up and down the driveway certainly showed a huge improvement.
I'll get round to it - some day! :bluewave:
new to this
#10 Post by new to this »
Latham_F2 wrote: Tue Nov 24, 2020 10:29 pm That looks very similar to the setup I ended up with during first lockdown.
Hi sorry dont know your name,have you jacked up the rear wheels,to test for clearance,only asking as when i did my brake set up, originaly had my brake calipers at a similar angle to yours,but when i jacked up the rear wheel the brake hose got traped between the body frame and caliper,thats why i moved the caliper round a bit more
Latham_F2
#11 Post by Latham_F2 »
Hi Dave, it's Tony.
The car is on axle stands in the pics, plenty of clearance.
But on these calipers the brake pipe exits from the caliper going forwards and down, it won't catch anything.
SprintV8
#12 Post by SprintV8 »
What are the 6R4 callipers your using.?
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
Latham_F2
#13 Post by Latham_F2 »
Metro 6R4. Probably from an early one.
I read that later ones had vented discs so required a spacer between the 2 halves.
#14 Post by soe8m »
Probably std. Metro turbo calipers. The 6R4 had alloy AP racing calipers.
cleverusername
#15 Post by cleverusername »
Carledo wrote: Tue Nov 24, 2020 7:58 pm I was gonna say much the same thing, but Dave beat me to it above^^^^
Yes that was my thought, why would a 1500 need rear disk brakes? The big drums on the Sprint need a valve to stop the brakes locking up and you're likely to need a similar system for this conversion, unless the fronts are upgraded as well.
To be honest I am not a fan of all disk setups on front engineed cars full stop. Most of the braking is done by the front brakes, so rear disks are pretty pointless. They just complicate the fitting of a handbrake, at least until electronic parking brakes were introduced. Drums are perfectly fine for rear brakes.
