Ethanol
Graham04
Ethanol
#1 Post by Graham04 »
Just picked this link up from another forum. Thought it would be of interest, once in, click on "what is the ethanol content".
https://www.esso.co.uk/en-gb/fuels-faqs
Manta
Re: Ethanol
#2 Post by Manta »
If you are using fuel with Ethanol in I would highly recommend fitting ethanol proof fuel hose, just fitting “Suitable for unleaded” hose is not Ethanol proof!
You can get the correct hose from
https://www.carbuilder.com/uk/ethanol-p ... se-10mm-38
or
https://www.advancedfluidsolutions.co.u ... -199-c.asp
1977 Dolomite 1850HL
1987 Opel Manta GTE
1987 Opel Manta 1800 Berlinetta.
Richard the old one
Re: Ethanol
#3 Post by Richard the old one »
Having read the post above I decided that I would see if I could find a specification for Ethanol safe petrol hoses on the internet. I did not find a spec but I did come across https://www.moss-europe.co.uk/ethanol-p ... gates.html which claims to be ethanol proof and is a lot cheaper than the previous suppliers.
bazyerma
Re: Ethanol
#4 Post by bazyerma »
Richard the old one wrote: Sat Nov 28, 2020 4:15 pm Having read the post above I decided that I would see if I could find a specification for Ethanol safe petrol hoses on the internet. I did not find a spec but I did come across https://www.moss-europe.co.uk/ethanol-p ... gates.html which claims to be ethanol proof and is a lot cheaper than the previous suppliers.
Thanks for the info, looking at the prices my 20meter reel I bought over 7 years ago for £20 wont be ethanol proof!
I am planning on replacing all the hard full lines as well on my 1500TC, any advice what size / Material to use for the hard lines?
Regards
Barry
Aberdeen
cliftyhanger
Re: Ethanol
#5 Post by cliftyhanger »
Manta wrote: Sat Nov 28, 2020 12:25 pm If you are using fuel with Ethanol in I would highly recommend fitting ethanol proof fuel hose, just fitting “Suitable for unleaded” hose is not Ethanol proof!
or
I would not touch the AFS stuff with a bargepole. I know of a few people where it has failed in under 12 months. So obviously fake. In fact, fake r9 hose is prevalent, only buy from a reputable seller (sadly AFS appears not to be one)
Moss, Burtons Rally Design etc all sell suitable stuff.
Magenta Auto Sprint
Re: Ethanol
#6 Post by Magenta Auto Sprint »
I have had issues with Ethanol fuel on my 1850 Auto, the R6 grade of pipe had started to break down, the small bits of rubber stick in the float needle valves, which on stombergs is a pain to remove and clean.
Everything after my fuel filter is no R9.
My 1300 and Sprint Auto are next on the list although they have SUs.
Malcolm
Re: Ethanol
#7 Post by Carledo »
bazyerma wrote: Fri Dec 11, 2020 9:08 am
Regards
Barry
When replacing hard fuel lines, I use 8mm microbore central heating pipe in copper. I's nice and easy to bend with a cheap pipe bender, fits the factory clips etc and of course, doesn't rot like steel. It's also cheaper than buying the "orrect" stuff from the factors. No downside that i've been able to discover.
oily66
Re: Ethanol
#8 Post by oily66 »
For this reason when I fitted my pipes I did the full length front to back in one run in cupronickel.
So the only rubber is at the tank end and in the engine bay so I can keep an eye on it.
Trevor
2017 Jaguar XE R-sport
Re: Ethanol
#9 Post by Carledo »
oily66 wrote: Sat Dec 12, 2020 8:18 pm For this reason when I fitted my pipes I did the full length front to back in one run in cupronickel.
You must have the patience of a saint and the luck of the irish, one slip and you've wrecked the pipe! Bend it with a pipe bender to get those nice crisp corners the factory ones have and you daren't get it wrong, you can't undo a bend. The Dolomega pipe I reduced to 2 pieces (stock is 3) and altered the join spot to get a fuel filter in alongside the inner sill, that was VERY hard to get right.
Manta
Re: Ethanol
#10 Post by Manta »
I also used in cupronickel in my car, did it in 3 parts though,
I used an 8mm External pipe bender, this made the job so much easier, with no squashed corners,
Highly recommended.
Good to see a cheaper supplier of the hoses in Moss.
1987 Opel Manta GTE
shaunroche
Re: Ethanol
#11 Post by shaunroche »
Richard the old one wrote: Sat Nov 28, 2020 4:15 pm Having read the post above I decided that I would see if I could find a specification for Ethanol safe petrol hoses on the internet....
When replacing hard fuel lines, I use 8mm microbore central heating pipe in copper. I's nice and easy to bend with a cheap pipe bender, fits the factory clips etc and of course, doesn't rot like steel. It's also cheaper than buying the "correct" stuff from the factors. No downside that i've been able to discover.
Hi Steve, when you made up the fuel pipe for me is this the size the pipe is....8mm O/D ish?
I ask as I'm wanting to order some rubber hose to connect it all up with and I'm not in the workshop to measure it!
What size I/D hose should I be ordering please?.....and clip I/D too please? :)
Re: Ethanol
#12 Post by Carledo »
shaunroche wrote: Tue Apr 09, 2024 12:56 pm
Yes Shaun this is what I made for you, so 8mm I/D hose is what you need.
Fuel pipe clips, you need 4 x 624155 (double clip with brake pipe for chassis leg) and 12 x 1509301 (single fuel pipe only) Fitchetts stock them, also Bresco and probably a dozen others. Bresco are often a bit cheaper but you have to convert their part numbers to OE which is very time consuming.
Whilst on the subject of fuel pipe clips, a word on fuel HOSE clips.
In my experience,a small worm drive hose clip ("Jubiliee" clip style) just doesn't cut it on fuel hose. It ends up as a sort of D shape instead of round! I don't recommend using the original spring clips either, as modern hose is almost always a little thicker than OE and the OE clips were made to suit a particular thickness of hose. Take my advice, go the extra mile and get the correct style of fuel pipe screw clips.
It's probably not quite so critical with carbs, but my EFi systems don't like worm drive clips one bit!
shaunroche
Re: Ethanol
#13 Post by shaunroche »
Yes Shaun this is what I made for you, so 8mm I/D hose is what you need.....
Steve, you're an absolute Gentleman and Guru, thanks for your help!...a large, disproportionate sum has now been spent on fuel hose and clips!
If I may…..
#14 Post by sprint95m »
To add to Steve’s post…
Pipes are measured by outside diameter
and hoses by inside diameter (bore)
( so for example a 32mm hose will fit onto a 32mm pipe).
Regarding hose clips,
for high pressure fuel applications I use O-clips
because they clamp both securely and evenly all the way around.
(O-clips are one mandatory choice for gas hoses I understand
but I don’t if the same is true for liquid fuels)
Ian
Re: Ethanol
#15 Post by Carledo »
shaunroche wrote: Wed Apr 10, 2024 9:53 am
The price of simple little plastic clips is scandalous! When I built up the Dolomega after it's respray, I used 100% new clips for everything, mouldings, badges, weatherstrips, brake and fuel pipes etc, which I bought all at once. The bill came to well over £200! And that didn't include dozens of assorted hose clips for coolant, fuel, fuel return, trans cooler, heater etc!
