engine block
new to this
engine block
#1 Post by new to this »
Is there an easy way to tell if its a TR7 block or an 1850 block
thanks Dave
Re: engine block
#2 Post by xvivalve »
Yes, bore size. TR7 will be 90.3 mm diameter, 1850 is only 87 mm
new to this
Re: engine block
#3 Post by new to this »
xvivalve wrote: Tue Dec 08, 2020 10:52 pm Yes, bore size. TR7 will be 90.3 mm diameter, 1850 is only 87 mm
Alun
thanks for imformation,but is there any way of telling the difference from the outside of the block
GrahamFountain
Re: engine block
#4 Post by GrahamFountain »
If the 1850 is like the Sprint, it will have a flaired tube for the dipstick where the TR7's is straight so that the long tube can fit over it.
But don't the engine number give it away?
Re: engine block
#5 Post by xvivalve »
If the engine is fully fitted, it is most likely a TR7 engine if it is wearing HS6 carbs with a carb brace linking them, whereas an 1850 should be on HS4 with no brace.
The TR7 backplate should have countersunk pins fixing it to the block whereas the 1850 should have bolts.
As Graham says, the engine numbers will be prefixed differently, the 1850 will start WF whereas TR7 will be CG or CL if reimported from the US/Canada.
GrahamFountain
Re: engine block
#6 Post by GrahamFountain »
xvivalve wrote: Wed Dec 09, 2020 9:46 am TR7 will be CG or CL if reimported from the US/Canada.
If it says CH, I'll buy it.
