Brake master cylinder 1500 auto
RJF_70
#1 Post by RJF_70 »
I have finally removed my Brake master cylinder, question is in all of the manuals / books I have, none of the master cylinders are the same as this, tried to add pics of it as its the seals leaking around the reservoir and is it a prise out job as no securing screws holding the reservoir to the master cylinder?
Any advice appreciated, thanks Rich..
1981 Dolomite 1500 Auto
Re: Brake master cylinder 1500 auto
#2 Post by xvivalve »
That is a standard RHD tandem cylinder. Most manuals/parts books were written whilst RHD cars still had the single line system, so the tandem ones illustrated are often those only fitted to LHD cars.
Yes, it is a prise out/push in connection for the reservoir, there are quite sizeable flanges on the bottom of the connecting tubes, so some force is required, particularly when fitting into new seals; the folk who recondition for use use a vice!
RJF_70
#3 Post by RJF_70 »
xvivalve wrote: Sun Jan 17, 2021 3:02 pm That is a standard RHD tandem cylinder. Most manuals/parts books were written whilst RHD cars still had the single line system, so the tandem ones illustrated are often those only fitted to LHD cars.
Thanks Alun, are refurb kits available easily, and advisable to check piston too I'm guessing? This unit is coming up 6 years old as it was part of a brake overhaul before I purchased car in early 2015. Being a Girling part that don't seem long really considering I've hardly used it for last 4 years! Although lack of use probably doesn't help either?
Thanks Rich..
#4 Post by xvivalve »
Refurb kits are available, but it's rare to see them with replacement reservoir seals. It may well have been 'new' a few years ago, but could easily have sat around for 30 years prior!
We have full reconditioned units in stock, sleeved with stainless steel, but they're £105 which is a bit more than the seal kits tend to sell for.
