Coil connections
Larry 1300
Coil connections
#1 Post by Larry 1300 »
I have installed a rev counter and a hidden switch to immobilise the engine. These are attached to the coil.
I want to disconnect these. Would you tell me the connections that should be on the coil. The power cable attached to the positive.On the negative post I will put the cable that comes out of the distributor on. Should there be any other cables attached to the negative terminal please. I have a Dolomite 1300 (1980)
Laurence
Laurence
Re: Coil connections
#2 Post by MIG Wielder »
Hi Laurence,
I think the 1300 should be the same as my 1850 as regards wiring in this area.
On the negative side of the coil there should be a White/ Black wire only to the coil to the distributor.
The White/ Slate Grey wire to the rev counter should be removed if that is your requirement.
On the Positive side of the coil...I'm not sure if you have the 1850/ Sprint ballasted system.
If you do, then there should be White/ Yellow wire from the starter motor ( to switch the ballast resistor ) plus a Pink / White wire from the ballast resistor, and nothing else.
Good luck with sorting it,
Larry 1300
#3 Post by Larry 1300 »
MIG Wielder wrote: Mon Mar 08, 2021 10:01 pm Hi Laurence,
Hi thanks that was very helpful 👍.
Laurence
