Sprint Crankshaft pulley
Aldpilot
#1 Post by Aldpilot »
It seems these are hard to find. I am after a crankshaft pulley for a Sprint part No. 217587. Can anyone suggest a source please? Rimmers cannot help and Wins sold their last one a couple of weeks back.
Thanks and hoping.
TrustNo1
Re: Sprint Crankshaft pulley
#2 Post by TrustNo1 »
Why do people think there is only one Triumph supplier there are many others that are usually cheaper.
Fitchetts, James Paddocks, Mick Dolphin, Spintspeed, Robsport, TDC, Abington parts, Moss. Ive probably missed some but i'm sure someone on here will have spare one anyhoo.
#3 Post by xvivalve »
I expect I can find one...
cleverusername
#4 Post by cleverusername »
TrustNo1 wrote: Fri Sep 03, 2021 8:41 pm Why do people think there is only one Triumph supplier there are many others that are usually cheaper.
For a start the OP mentioned two suppliers, not one and it is perfectly possible that a new owner would be unaware of other suppliers. Not everyone has owned old British cars for decades and built up a knowledge of such things.
#5 Post by soe8m »
Buy an 1850 one and machine some length off. Also a used 1850 one will do as the seal will be on an unused area.
Aldpilot
#6 Post by Aldpilot »
Thanks guys. I had tried all the usual places before posting, but not Sprintspeed. They do an adapter for a BMW pulley. Anyone had any experience of using this? Jerome’s suggestion is beyond my abilities, but I can probably find someone who can do the machining needed if that is the way to go. Alun, if you can find a serviceable one, I would be most grateful. Anyhow the issue has not gone away, so any help on this would be welcomed.
Aldpilot
#7 Post by Aldpilot »
Retro engineering look to do one at £192+PP. Anyone used one?
https://shop.retro-engineering.co.uk/do ... -267-p.asp
#8 Post by xvivalve »
Mike,
So far I’ve found one Sprint one which has a register mark on it, see photo’ and 3 x 1850/TR7 type. If you don’t like the look of the Sprint one, I could get a price from our panel fabricator for turning a longer one down as he bought Ted Middleton’s lathe from his step daughter…or I may find better Sprint items when I look further than the box in my kitchen…
#9 Post by xvivalve »
Aldpilot wrote: Mon Sep 06, 2021 11:42 am Retro engineering look to do one at £192+PP. Anyone used one?
I don't believe that one has the integral damper?
Aldpilot
#10 Post by Aldpilot »
Thanks Alun.
Part is needed to get us around RBRR, so not much time to source a solution. The current pulley has slipped and it has only just come to light. I have just posted on the CT RBRR thread to see if anyone has one tucked away. Thanks for your help so far. Fingers crossed something pops up soon. Machining will be our last resort if things don’t come together shortly.
#11 Post by xvivalve »
Found a second Sprint unit with far less pronounced a lip
Aldpilot
#12 Post by Aldpilot »
Alun has come up trumps. Thank you
