Rear Right Brake Bleed
jlan1978
#1 Post by jlan1978 »
Hi All
Regarding bleeding the rear right brake drum, I'm not seeing anything obvious, there looks to be a nipple near the axle is that it?
Re: Rear Right Brake Bleed
#2 Post by xvivalve »
If it's a Sprint, you bleed the rear from the left only.
The bleed nipple is on the back of the wheel cylinder where it protrudes through the bottom of the backplate.
Bumpa
#3 Post by Bumpa »
Not just the Sprint either. My 1977 1850HL only has the one rear bleed nipple. I was very sceptical when I first filled the new brake system, but it bled easily.
cleverusername
#4 Post by cleverusername »
Bumpa wrote: Sat Sep 18, 2021 7:39 pm Not just the Sprint either. My 1977 1850HL only has the one rear bleed nipple. I was very sceptical when I first filled the new brake system, but it bled easily.
If you look at the pipe work, the brake cylinders are connected in series, so you have to bleed them as one unit.
dursley92
#5 Post by dursley92 »
Same single bleeder set up on TR7s as well.
Russ Cooper
Dursley
UK
