Valve spring retainer - cracked!
roger440
#1 Post by roger440 »
Having decided to strip my engine down to sort out the bore scoring, ive been busy cleaning up the various parts.
Cleaning up the valve spring retainers, out of the 6 so far, 2 are cracked!!!!
No pics, phone was flat :(
Around the spring locating ring/shoulder.
The engine runs an STR91 cam, and uprated valve springs, as purchased from Moss/triumphtune back in 1994. Engines done less than 5000 miles in this guise, though who knows what mileage the retainers have done.
Is this a "known issue" when running uprated springs?
Whats the solution? I see sprintspeed do titanium ones. Is this the go, or are there other options?
1970 Triumph 2000 Estate w/ RV8
1980 Triumph Dolomite Sprint
2003 Holden Ss Ute
1969 Dodge Charger
1973 Triumph Stag
1961 Standard Atlas
Re: Valve spring retainer - cracked!
#2 Post by xvivalve »
It's not something I've encountered...but then it's also something I've not specifically looked for...
I have a quantity of used retainers and will look them out to see if any are similarly fatigued...
SprintV8
#3 Post by SprintV8 »
May be worth checking the valve springs clearance between coils on full lift..
Think it’s called binding.
Use to have this problem with the race Minis many years ago.
Mainly traced back to valve bounce.
Titanium retainers where not a option then.
I pretty sure Newman cams done us a slightly rework cam to cure the problem.
Are cams where all out race cams..
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
SprintV8
#4 Post by SprintV8 »
Only just remembered.
The Sprint engine that was in mine originally was sold.
It then went into a TR7.
It broke a couple of Caps on the M2.
Must be a age thing.
MERRY CHRISTMAS 🎅.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
