Carb Model
Malsprint
Carb Model
#1 Post by Malsprint »
Can anybody tell me the model number for these carburetors.
They are from a 1980 Sprint but that is of course no guarantee that they are the original carbs for the car
yorkshire_spam
Re: Carb Model
#2 Post by yorkshire_spam »
They look like SU HS6, is there any sign of a small triangular tag attached to the top of the float bowls on either carb - the tag typically tell you the variant.
Bodies, bowls, domes, pistons etc. tend to be common to HS6, but the needles and angles of the bowl adapters varies from model to model.
Re: Carb Model
#3 Post by xvivalve »
They are HS6 ok, but not original to a 1980 car, they are much earlier. A 1980 car would have had wax stat carbs.
Originally the colour of the jet would have identified which of the three types of non wax stat they were, but over the last 50 years these could have been changed.
dursley92
Re: Carb Model
#4 Post by dursley92 »
xvivalve wrote: Sat Feb 19, 2022 9:49 am They are HS6 ok, but not original to a 1980 car, they are much earlier. A 1980 car would have had wax stat carbs.
Could just be the owner threw away the waxstats when he did a rebuild and fitted the aluminium mounts
Russ Cooper
Dursley
UK
Re: Carb Model
#5 Post by soe8m »
No different body also, the early types. This set is of a 1973/1974 sprint.
