The never ending leak, windscreen removal
cleverusername
#1 Post by cleverusername »
My quest to have dry footwells continues, after they looked like Loch Ness after the storms. Going on a hunch I took an angle grinder to the box section under the windscreen and found a lake in there.
So I have had to bite the bullet and remove the screen. On the nearside this has revealed the problem, once I took a belt grinder to the windscreen surround, it was rust being held together by paint. On the off side I have a leak but everything looks solid but I am suspicious of the quality of the windscreen fitting.
I got some pros to do it because I thought they would do a better job than me. However it was incredibly easy to remove. On Youtube I see people having to use both feet to get the thing to budge. I managed to get mine out with one finger, once the locking strip was out, it was very easy to remove. Does that indicate it was fitted poorly?
new to this
Re: The never ending leak, windscreen removal
#2 Post by new to this »
You cant really fit a windscreen wrong,as long as the screen fits in the groove of the rubber and the rubber fits in the screen opening correctly,i use sealant around the corners when i fit them.i think you can only get one make of rubber for the screen
Have you got any pictures of the rust in the corners ?
cleverusername
#3 Post by cleverusername »
new to this wrote: Sun Feb 27, 2022 6:08 pm You cant really fit a windscreen wrong,as long as the screen fits in the groove of the rubber and the rubber fits in the screen opening correctly,i use sealant around the rounders when i fit them.i think you can only get one make of rubber for the screen
No, I could take some tomorrow but you will be looking at a hole because I cut out all the rot. The lip the rubber fits on was just rust and the metal beyond that was paper thin. Plus there is now a big hole under the screen, more paper thin metal. It looked OK when I had the screen fitted but experience has taught me an amazing amount of rust can be hidden by paint.
The rubber was not a tight fit, so I suspect it is another example of suspect modern parts. My plan is to seal the lot when I refit it, belt and braces.
new to this
#4 Post by new to this »
cleverusername wrote: Sun Feb 27, 2022 6:42 pm
Have you use the rust converter,i know it wont work on really thin rusty metal,was it a new windscreen rubber you fitted ?
#5 Post by Carledo »
What it indicates to me is that it was fitted without ANY sealant at all, a recipe for disaster.
As with all things Dolomite, tolerances vary! I've had screens that have almost fallen in (like yours fell out) and others that have fought me tooth and nail to get in. Never seen one yet that would go in dry and not leak.
cleverusername
#6 Post by cleverusername »
new to this wrote: Sun Feb 27, 2022 7:44 pm
Rust convertor is next to useless, all it can do is stabalise rusty metal. Its only use is on surface rust when there is a good depth of metal remaining. Even then you need to clean the majority of the rot off to have any effect.
Once it is paper thin, your only option is to cut it out and weld new stuff in.
cleverusername
#7 Post by cleverusername »
Carledo wrote: Sun Feb 27, 2022 7:48 pm What it indicates to me is that it was fitted without ANY sealant at all, a recipe for disaster.
No sealant and the stuff I tried to put in later barely made it under the seal and was a waste of time. Believe me, I will be sealing the whole frame when I refit.
BobM
#8 Post by BobM »
Dry fit seals were developed in the mid 70s and it should be remembered that the Dolomite shell is a mid 60s design.
The gap behind the rubber should be filled with sealant. You will find that many current glass fitters, skilled as they are, have no experience of older vehicles.
Always use a generous amount of sealant and remove all rust and protect any bare metal before refitting any glass.
TrustNo1
#9 Post by TrustNo1 »
The filler strip is NOT there to expand the rubber and is not any form of locking seal its just to look pretty and if fitted properly (yes it can be done wrong) you shouldn't need any sealant I have never used any sealant on Dolomite screens.
Bob M states that the Dolomite is a 60s design, this isn't entirely true as the screen surround panels were changed slightly from the earlier triumph FWD range.
cleverusername
#10 Post by cleverusername »
TrustNo1 wrote: Mon Feb 28, 2022 8:07 pm The filler strip is NOT there to expand the rubber and is not any form of locking seal its just to look pretty and if fitted properly (yes it can be done wrong) you shouldn't need any sealant I have never used any sealant on Dolomite screens.
I know this is a controversial question but is the issue the fact I have a laminated screen?
The seal fit was not tight, easy to remove and water was getting past the seal on the glass and metal sides. Which suggests it is the wrong size.
#11 Post by Carledo »
cleverusername wrote: Mon Feb 28, 2022 11:35 pm
Lets put this to bed once and for all. There is and has only EVER been one part number for the screen rubber. the theory perpetuated by Jonners, (God rest his soul) that the screen rubber was for toughened screen only, really is only an urban myth. In any case, i've personally measured a toughened and a laminated screen and the laminated is THICKER by about 40thou which makes a final nonsense of the theory. The only rubber you can easily source at the moment is the Baines made one. whilst I have some quality issues about these, it's more concerned with cracking and ageing in storage, not fit! If the machinery that extrudes it got worn, it would end up thicker (which is good) The tolerance in the shell, especially on later cars when the panel tooling was well past it's renewal date, will be far bigger and more random than anything in the rubber!
I recommend buying fthe rubber from Baines direct, that way you can be more sure it hasn't been on someone's shelf in the sun for 5 years before YOU get it.
naskeet
#12 Post by naskeet »
Since before my father bought it in May 1975, as an ex-demonstrator that had been registered since mid-November 1974, my four-door, 1974 Triumph Toledo 1300 "HL Special" has been fitted with a laminated front windscreen; "originally" of Triplex brand, later replaced by one of "Solaglas" brand (with a blue shade band at the top), when the "original" one cracked owing to a stone-chip.
Regards.
Nigel A. Skeet
