Trackerjack rear brake cylinders
RichardHyde
#1 Post by RichardHyde »
Morning all,
I believe that GWC1502 rear wheel cylinders are recommended when using Trackerjack brakes. Is there any way to identify these without removing from the car and measuring the bore ?
Thanks, Richard
killysprint
Re: Trackerjack rear brake cylinders
#2 Post by killysprint »
the brake cylinders should have the bore size cast into the casing on the area where the bleed nipple and brake line screw in
I've had both mine replaced this week with NOS unipart ones and they had the bore size on them.
I have trackerjack brakes and have gone with std sprint (the larger bore) cylinders
Hope this helps
1976 Taihiti Sprint
2024 volvo XC90 T8 Hybrid
2021 Toyota Yaris GR-Four
2015 Audi RS4 Avant (V8!!)
