Clutch Master Cylinder
Posted: Sun Jun 19, 2022 7:25 pm
I am after some help in respect of the pipe that goes from the reservoir to the clutch master cylinder..
My question is should the union that screws into the master cylinder be flush with the top of the cylinder itself? A union on its own seems to screw all the way, but with a flared pipe it doesn’t…. Despite numerous efforts and 3 new pipes it doesn’t seal and continually seeps fluid from around the union…
With the cylinder, slave and main clutch pipe from the master to the slave being new I believe this is the only point at which air can be getting in to prevent bleeding and thus the clutch not working. Unless of course one of these new cylinders is faulty in some manner, and if they potentially are, how would i be able to identify the problem please..
I have had the slave off today and checked it visibly and all seems well and as you would expect with a new slave cylinder..
Any ideas or help appreciated
James
James
