Heater controls fascia removal tips. Dolly 1500hl
Posted: Tue Jul 19, 2022 5:10 pm
by Zeus
Hi all,
Any tips on removing the heater fascia so I can get at the gubbins behind.
One lever is bent and needs straightening and a cable has popped off another.
Manual says two screws hold on from inside but how do I getbto them?
Re: Heater controls fascia removal tips. Dolly 1500hl
Posted: Tue Jul 19, 2022 6:08 pm
by yorkshire_spam
Dash unscrewed and pulled forward, glovebox + clock out, then get at the screws from each side. Massive faff.
I managed to re-attach the cable to the centre control with the dash and glovebox out without removing the clock and fascia just to avoid the extra messing about.
Posted: Tue Jul 19, 2022 6:38 pm
by naskeet
Zeus wrote: Tue Jul 19, 2022 5:10 pm Hi all,
Make sure each of the control levers are properly centered in each of the trim-panel slots, otherwise over time, the levers will scrape slivers of plastic from the edges of the slots. This is something which happened with my original factory-fitted Toledo dashboard! :evil:
