Con Rod bolts/studs
new to this
Con Rod bolts/studs
#1 Post by new to this »
How do you remove the con rod bolts/studs ? is it a matter of knocking, them out from the top of con rod
Is it also possible to remove the con rod bolts while the rods are still in the block ?
thanks Dave
dursley92
Re: Con Rod bolts/studs
#2 Post by dursley92 »
They knock out after you have undone the cap but I think you would struggle to do it in situ. And why?
Russ Cooper
Dursley
UK
